Had this issue for awhile, just can't spot the cause..... Car lacks all power and barely moves at even full throttle while below full operating warmth, although if it builds positive boost, takes off right away while cold.... second it reads full warm it gives one final minor jerk as timing corrects and all is normal.... real pain in the butt come September temperatures.
For example flooring it 1000 to 3000 rpm you only move like 10 kmh, second you hit boost you jerk forward with all normal acceleration.... car is not driveable like this, until full warm. Specifically the issues is that timing is pulled to 6 deg btdc, hit boost or get to full warm, back to 25+ btdc as usual.
I've replaced or done trouble shooting on CAS, Knocks, water temp sensor, replaced ecu, checked base timing, MAF.... only thing I can think of is TPS, which is normally adjusted and sweeps fine....
Should also mention, that on occasion it will start and run normal for a minute until something is 'detected' and timing is pulled, becomes sluggish ect... no codes have been thrown....
advice??
advice??
