Bought the car in December. It ran like ****. Car would miss, and pop. Changed out injectors, coil packs, coil pack harness, injector seals, Z32 fuel filter, maf, plugs gapped at .08 like recommended. Fuel pump, regulator, and other things. We'll the car fires up with hesitation at times. When driving it seems fine, while cold. Once engine is at good temp I'll open it up in first gear and @ around 5psi it breaks/cuts out. No wideband, so I check plugs. They are pretty darn white. So it's leans. My fuel pressure is 40 psi.. Now after that the car will run like **** from idle to around 2,000 RPM. After that it clears out. But you still can't WOT without breaking up at 5-6 PSI. The car is all stock but 3' exh, filter, pump, and 10 psi. Wtf.. Someone help everyone that has looked at it is stumped. Oh and timing is dead on..
