I am new to the skyline scene. I just recently purchased my first skyline and brought it back to the USA. This is what happened. I drained the gear oil through the plug at the bottom and then realized that I could not get the filler plug off. So I put the gear oil through the shifter. After I got it all put back together and took it out for a drive I noticed that the clutch felt way easier to push in and whenever I would push in the clutch while still in gear going down a hill it sounded like the gears were grinding. What could be the issue? I used red line 75w90. What would be the cause of the soft clutch? what would I have to do to fix it or have it fixed?
Thanks
Thanks
. As Bobbo said you have have just ran a dry transmission.
