Since last pull with my car, when I press the throttle halfway + on boost, the engine hesitate...on fourth and fifth gear, the trouble is not so bad (even better when the engine is not 100% warmth) It seems like misfiring (strange sound, hesitation and around 13.8-14.1 A/F ratio)
It also got lean a few times when idling (16.1+)
Also, happened 2 times randomly
I start the engine, all is good. Getting to grocery (engine is 100% warm'd up) stop the engine. Then when i get out after 5mins, I turn the key, reverse, the engine stall........I try to restart, crank but not able to restart.....I try a few times, and finally, it starts again!
Since then almost a month....I do not drive it, fearing to be in trouble
I cleaned the maf, open'd it to see the solderings, all is good. Changed the spark plugs too, coils wiring is new, bought it 2 years ago
thanks!
thanks!
