Setup:
rb25 series 2
800cc sard injectors
AEM ems series 2, AIT, boost solenoid, wideband
from facing intake mani
stock turbo (for now)
wiring specialties wiring harness (RB25 to standalone)
CAS with aem trigger wheel
q45 TB /w q45 tps
GM 3bar map sensor
I've been trying to fire this up for the past few days now and am trying to get more input on what's wrong or what i'm doing wrong.
I have a few small issues so far.
Right now my MAP sensor is only reading .14v but not showing a sensor error. I'm almost certain my MAP sensor is faulty as it shows -13psi when the engine is off. Also, pressure doesn't change when blowing into the hose that leads to it. Could this also possibly be a wiring issue?
Another issue I'm having is that the Stat Cranking seems to always be on and stat running turns on when cranking. I was told that stat cranking only turns on when you are cranking the engine and stat running when the engine fires up. totally lost on this one as i have no clue where to start.
[IMG]
[/IMG]
On a positive note, i seem to be getting fuel and spark. I have a guess that my timing is off so i'm gonna double check the position of cylinder #1 so it matches up to TDC with my CAS.
Your RB/AEM Expertise is highly appreciated
rb25 series 2
q45 TB /w q45 tps
GM 3bar map sensor
[IMG]
[/IMG]On a positive note, i seem to be getting fuel and spark. I have a guess that my timing is off so i'm gonna double check the position of cylinder #1 so it matches up to TDC with my CAS.
