having a really hard time with this code 21 ****. heres the deal I have a rb25det neo, I also have a nistune type 3 board. and the car has been running without ant problems. until last week. I was driving and it looked like my power was dropping when I would press the throttle(like from 12 to 10volts).
stopped the car, turned off the lights, removed the alt fuse(which wasn't broken) re stuck it back in and never got car to start again.
until.......
I sprayed the throttle plate with lots of starter fluid, and unplugged the maf. the weird thing is the car would run after some tries for like almost a minute. but when I press the gas or plug back up the maf it would die.
it would die because the fuel pump won't prime and there is no fuel in the line??
so I ran a positive wire to the pump(after I brought and returned a new pump). and the pump I had all along works.
so even running positive power to the fuel pump and trying to crank it over is no dice??
ignitor you say??
well I have ls1 coil packs with the ignitors built in so that can't be it. and again my problem lies with the fact that my fuel pump won't turn on..
here's what I have done.
-jumped the fuel pump relay
-gotten another z32 afm(brand new)
-changed the fuel pump
-changed the cas
-got a new ign switch for the key(actually needed this for down the line)
-got another z32 ecu
so I tried all of these and my damn car still won't start. iam stumped and this is getting pretty pricey and tedious seeing as iam stuck and my car is out of state on a side street.
what do you think??
until.......
ignitor you say??
-changed the cas
what do you think??
