I'm planning to put an RB25Neo with transmission in my R32 gts-t.
The car is mostly for drifting and track.
I don't want a whp monster, I want something solid that can hold abuses.
What I plan to do on the rb25 :
Poncam + adjustable cam gear, hks-gtrs turbo, injectors, intake N62(from 300zx) and alumium driveshaft.
Questions so far :
1) I want to keep the engine internal as it is, what poncam should I use :
Tomei 260deg or the Tomei 252deg ?
2) What boost should I have with stock internal engine ?
3) Is the rb25 ECU can be used or should I use a 300zx ECU like some say.
4) Transmission mount, where can I get one or where I can get the measurement to make a custom one ?
5) Where can I get the measurement for the aluminium driveshaft ?
thank you !
Questions so far :
thank you !
