what are you gts guys running for caster? I'm at 6 degrees and I just put 245/45zr17 - 17x9 +30 on my gts and it rubs when turning at the rear of the wheel well where the side skirt is.. wheel is definitely closer to the back in the wheel well. Any ideas?
245/45/17 rubbing help
Get a spacer and roll your fender? Or 235/45/17?
I'm having a similar issue now(18x8 +35 I do believe) I'm rubbing the plastic liner in the back and if I'm say driving up a slight grade on an angle, I'll rub the fender if turned. I'm gonna roll the fenders to stop the rub and may pull out the liner and rock guard the wheel-well.Last edited by future_R34; 11-04-2014, 03:57 PM.Come on lotto!!! Daddy needs a whole lotta stuff!
