Hey everyone, I'm trying to figure out the best setup for my RB25det, if a Z32 MAF will be good for running ~17psi
MAF question
MAF question
Started rebuilding my skyline when i was 18
1992 GTST RB25DET
http://forums.gtrcanada.com/gts-project-cars/54849-saved-my-car-great-scrap-heap-sky-redo-my-first-car-thread.html
Originally posted by BravoPS My wife just told me I was shitting in your Cheerios!
I'm sorry,
Good luck!Tags: None
Boost level would vary based on turbo size. A bigger turbo would move more air at the same boost level thus max out the MAF voltage at a lower boost level.
Look at the CFM when the MAF maxes out the voltage (calibration) and convert CFM to hp. That's usually done for you. Normally a Z32 MAF is good for around 480hp at engine, which is around 416rwhp.
A Ford Racing Lightning MAF is good for up to 700hp at engine and can be run in blow throw confirguration, which is inbetween intercooler, intake manifold (stock is a draw through MAF / mounted just before turbo).RESPONSE MONSTER
Yea I'm going to hope to make ~400hpStarted rebuilding my skyline when i was 18
1992 GTST RB25DET
I'm sorry,
Good luck!
RB20DET, RB25DET stock MAF is rated to around 300hp at engine. There's tricks you can use to extend that limit, but best to upgrade the MAF. Also the CFM is the amount of air flowing through the round part of the MAF.RESPONSE MONSTER
