Hey guys,
A little intro and history to the car. It is a 91 r32 w/ controller, fmic, bov. Before I got it, it was sitting in a garage with couple years old fuel. I drove it home with that **** fuel (idk might play a factor).
Let's start with the symptoms.
1. Unable to start at any temp. (will only start if I "feather" the pedal)
- I cleaned the AAC valve and throttle body. Car now starts without feathering, but not instantly like a normal car.
Also, the car would die out at idle easy sometimes. Getting a new ignitor solved this problem.
2. There is a ticking sound on the intake side; it sound like a pencil tapping (I'm assuming that this is an injector). Note: When i rev the engine, I can't hear the ticking anymore (maybe because of the loudness of the engine itself); however, when the car is coming back down to idle, the ticking comes back at a faster pace and then slows down back to its original idle speed pace.
3. The main symptom
At any gear, when I reach 10 psi whether it be WOT or LOT(little open throttle?), the car bogs/hesitates/judders and does not accelerate anymore past its current rpm unless I ease off the throttle. If i open the throttle at a hairline keeping the boost under 10 psi, the car will slowly continue to climb rpm no prob.
Note: If I am in idle, I can WOT and the car will climb nicely. Bogging occurs when in gear. Car has power to lose traction initially in 1st but starts to bog (or lose power) when it catches (reaching 10psi threshold?).
Now what I've done.
1. New battery.
2. Cleaned AAC, throttle body, MAF (did not check resistance. Don't even know what the resistance should be.)
3. Basically new ngk bcpr7es-11. Not fouled.
4. Sealed coil packs with liquid tape, electric taped the boot, and lubed her up with dielectric grease
Resistances came back to 0.9 ohms.
5. Re-sleeved intercooler piping for boost leaks. (Note: I have not checked for a vacuum leak yet).
6. New ICM.
7. Checked the CAS. Injectors click away as does the plugs.
I am going to have to check the MAF and TPS resistances to ensure that they are operating normally. Anybody know the range?
3. The main symptom
Now what I've done.
1. New battery.
Resistances came back to 0.9 ohms. 5. Re-sleeved intercooler piping for boost leaks. (Note: I have not checked for a vacuum leak yet).
6. New ICM.
