I was talking about the loss of boost. Can lose around 1psi of boost from running engine lean + ECU pulling ignition timing due to knock.
The missing part is most likely the MAF + boost cut or airleak around the MAF somewhere or weak coilpack.
When the hotwire burns out it goes black on the cylinder part of the hotwire and that black spreads onto the wire next to the cylinder part. If cylinder part looks dark brownish (which most are at this age, high km) then it should be ok. You'll need a magnifying glass to check the hotwire out and good light (sun light).
TPS affect's transistion fuel enrichment. TPS + ECU settings prevents engine going suddenly lean when throttlebody suddenly opens (suddenly lean = hesitation, then engine accelerates). From what I understand, it's there because the MAF is to slow to react to sudden changes in airflow.
