trying to get the check engine light off in my r32. first off, the car runs fine, did a neo swap on my r32 and obviously didnt install the traction control system. I had originally bought a stagea ecu to avoid the code(stagea=no traction control) but i now have a mines r34 GTT ecu and the code is back. Basically i need to know how to trick the ecu in thinking the traction control is working.
its code 46:Throttle motor Sensor signal circuit.
theres four wires to the ecu that didnt get hooked up during the swap.
Pin 51: Throttle motor Sensor Signal
Pin53: Motor throttle switch
Pin 37: throttle opening Signal
Pin 79: ECM-TCM, TCS/ABS Integrated Control Signal(multiplex communication)
can i connect two of these four wires? add a resistor somewhere? ground a wire? a big concern is frying my mines ecu so i dont want to just ground a wire and see what happens.. any ideas??
