this may have been asked, but i didn't find anything in Search, so here goes..  1991 GTS4 with the RB20 has bad hesitation under full throttle acceleration.  But, when i push the throttle slower, it seems fine.  I dont' have a boost gauge, so i don't know if i'm losing boost, but I'm wondering if anyone else has run into this, and what the solution may have been.  I haven't done a tune up yet, either, so i know that's a possibility.
hesitation under boost at full throttle
 Both you guys could be right on this.
 I'd suggest the following trouble shooting options to do,
 1. Check your plugs and the gap on them. Running higher then 10psi they have to gapped at 0.8mm to ensure you don't get blow out in the higher rpms.
 2. Check the resistence on your coilpacks, they should read between 07.09 Ohms.
 3. Make sure your fuel filter good.
 4. Clean the MAF even with just a spray cleaner.
 5. Make sure your timing is correct.
 6. Check the TPS (i have'nt done this personally and im not familiar with how to do it) see that it's working properly.
 I know it's a lot of crap to do but thats the thing when it comes to trouble shooting, you gotta do all this in order to find out what exactly the problem is.
 Good luck and let us know if you need anything else.
 Cheers 8)RHD DriftinG, DoeS iT GeT AnY BetteR????
 Project GTS-R: 1992 R32 Skyline GTS RB20na-> Turbo
 Mods: A few things . .
 Dyno Results> 209.2whp/196FtLb @ 7psi
 Don't forget, we're using the new coversheet on the TPS reports now. Didn't you get the memo?Originally posted by sidewazegtst
 ^ Obscure 'Office Space' reference
 PS: I'm sorry - I know it's completely off topic, but I really couldn't resist. I tried to fight the urge...but hey. Sorry JZ et al.GTRC Geriatrics Crew.
 I would put money on the MAF being your main problem.. if there is anyone in your area that you can swap to confirm it that would be sweet..
 When that MAF is just starting to go you will be able to rev freely when in neutral but under load it will just stutter and have no power at all..The Evil 4 Door
 Nissan Skyline GTS-4 Sedan
 would it be worth the money to just swap in a MAF from a Z32? The car currently has a 3" exhaust from the turbo back with no cats in it, and a K&N drop in filter. To my knowledge those are the only engine mods.....Originally posted by BigBlueR32I would put money on the MAF being your main problem.. if there is anyone in your area that you can swap to confirm it that would be sweet..
 When that MAF is just starting to go you will be able to rev freely when in neutral but under load it will just stutter and have no power at all..-Shane
 If you swap to a Z32 MAF you'll need either an SAFC or ECU tune in order to use it.
 Honestly man do all those trouble shooting methods first, then evaluate the situation after that. I mean you could swap the MAF and still have the same problem. You need to figure out exactly what it is first before spending money where you don't have to. Only a suggestion. RHD DriftinG, DoeS iT GeT AnY BetteR???? RHD DriftinG, DoeS iT GeT AnY BetteR????
 hey my skyline sorta does the same, this is my first turbo car so im not sure, but it seems like up to 3000rpm it lags then once it hits 3000 it explodes, like, my gf's stock crx beat my skyline off the line untill i hit 3000rpm. and it seems to do this in all the gears
 think its the same problem?
 Generis Labs - JDM Parts Specialist - generis-labo.com
 Originally posted by JZGTRC Rules.
 Read it.
 Learn it.
 Live it.
 Peace.
 Sounds like boost lag to me.. hehe.. would need to feel what you mean exactly.. :POriginally posted by Stevo_323hey my skyline sorta does the same, this is my first turbo car so im not sure, but it seems like up to 3000rpm it lags then once it hits 3000 it explodes, like, my gf's stock crx beat my skyline off the line untill i hit 3000rpm. and it seems to do this in all the gears
 think its the same problem?The Evil 4 Door
