im pretty sure its just turbo lag
hesitation under boost at full throttle
Well I'm positive (at least in my case) it's lag now that I've cleaned my MAF. Since doing it though, responce is better and smoother but for sure boost still comes on around 3000rpm's. From that point though yeah she kicks!
RHD DriftinG, DoeS iT GeT AnY BetteR????
Project GTS-R: 1992 R32 Skyline GTS RB20na-> Turbo
Mods: A few things
Dyno Results> 209.2whp/196FtLb @ 7psi
I had that problem with modified stock BOV, where you come off throttle, then get back on throttle when off boost and it would lag, then car suddenly moves. I changed to Synapse BOV and it just picks up with 0 hesitation.
Sometimes gasket under stock BOV can be crushed too much thus causing a hard to find airleak hence the lag.
In some cases it can be due to intercooler is too big (takes longer to fill a bigger size intercooler at lower rpm's), as shown in this link -
http://www.are.com.au/techtalk/intecoolersMR.htm#Turbo Lag
If rev engine higher in lower gear, then punch it, the lag should be less, as shown in above link.RESPONSE MONSTER
