Bottom end :
Wesico 86.5mm pistons
Tomei H beam rods
acl race bearings
ati 1000hp damper
Tomei hi flow oil pump
Greddy trust sump extension
Arp Main studs
Brand New oem nissan r34 crankshaft
custom crank collar to give .02 clearance on oil pump inner gear
N1 water pump
Head:
Tomei procams 270 duration 10.25mm lift
Supertech dual valve springs with titanium retainers
supertech valve guides/seals
Greddy Timing belt
Arp Head studs
tomei 87mm 1.2mm head gasket (and full tomei metal gasket kit)
Oem nissan gasket kit
tomei adj cam gears
5 angle valve grind!
Turbo Kit:
Borg Warner S300x 91-79 t4 turbo with a .91ar twin scroll exhaust housing
Tial 60mm wastegate
Twin HKS ssqv3 limited black edition bovs
6boost true t4 twin scroll equal length manifold!
Fuel:
tomei 11mm fuel rail
precision 1000cc injectors
Custom swirl pot fed by stock gtr fuel pump
Inline aeromotive a1000 fuel pump
All stainless steel braided fuel feed and return lines from the pump to the rail
aeromotive a1000 fuel pressure regulator
Drive train/suspension
weakest link of build)
Tranny will remain stock for the time being i am going to pop through alot of them most likely but we will see
clutch is a os giken twinbdp440
Zeal coilovers
nismo tension rods
ams upper control arms
larger front and rear sway bars
nismo engine/tranny mounts
solid rear subframe bushings
Cooling:
Trust 30 row oil cooler with oil filter relocation with all ss braided lines
koyo aluminum rad
twin 10" electric fans
aem water meth kit
been a project for 11 months now and i finally hopped on the dyno. it was tuned at rg in bc and many of you know the "heart breaker dyno" we were only able to run low boost (12-13 psi) my os giken twin wouldnt hold any more power. so im up grading to a osg r4c or a exeedy triple carbon and going back for ~29psi. anyway here is the dyno sheet.
Tomei H beam rods
acl race bearings
ati 1000hp damper
Arp Main studs
N1 water pump
Head:
Greddy Timing belt
Arp Head studs
tomei adj cam gears
Turbo Kit:
Tial 60mm wastegate
Fuel:
weakest link of build)Tranny will remain stock for the time being i am going to pop through alot of them most likely but we will see
Zeal coilovers
nismo tension rods
Cooling:
koyo aluminum rad
aem water meth kit
