K so as you know im a newb to all this stuff so im just wondering which engine is better for reliability, gas mileage, and other things. i want to know in your opinion which is better for things like that?
RB Vs. SR
well i assume your talking RB20 vs SR20?? from what i understand the SR20 has more aftermarket support than the RB20...
My car has an RB20 and iv been driving it for 8 months without any problems. the gas milage isnt great but its what you would expect from turbo charge inline 6.
Both the RB20 and SR20 are both very capable engines.
thats all I really know.. im fairly new to nissans, coming from a DSM background my favourite 4 cylinder engine is still the 4g63t over the SR20.1991 gts4
what horrible question...
you need to ask yourself:
1)what is your desired goal? what do u want to end up with here? whats your purpose... for the car i mean obviously.
thats what will tell you which engine is better for YOU..
its not that SR > RB or RB > SR... each is different and used for different things
SR's have been proven great drift engines (once rebuilt) can really handle sustained high rpm's .. RB's are waay better for touring cars that travel at high speeds and do turns...
just think about the platforms each was offered on.. RB 4 wheel steering, 4WD... SR = RWD only.The SkyLife Community & News Website --> http://www.skylife4ever.com
Im asking for opinions cause im trying to decide weither i should spend my money ive saved up from doing landscaping and concrete, on a beat up 180sx or a R32 GTS-t.....
And like i said im a "Newb" to this stuff so dont expect the best questions....
ill help you a little more...
google the following and browse through what you see... this is what i did to learn about these things when i was newb:
- JB skyline
- Tyndago
- skyline history -skyline story
read through those, see what you fancy. theres nothing super special about the SR..
personally if i were you, forget the beat up 180... and go for the GTS-T.. post up some pics of each and we'll tell u what we thinkThe SkyLife Community & News Website --> http://www.skylife4ever.com
Both platforms with SR20DET + S15 or RB20DET + R31 are about even performance wise. At least the laptimes reflect this in Australia when using similar setup / chassis.
Basic formula is more cylinders, more capacity = more reliable engine. That's why some supercars have V12 engines with 6 litre or so capacity.
4cyl hits safe hp limits of pistons (100hp per cylinder for cast pistons or 400hp total) earlier than 6 cylinder (100hp per cylinder or 600hp total) due to amount of cylinders.
To back that hp per cylinder up, this RB20DET produced around 560hp (close to 600hp) at engine or 500whp with stock pistons, stock conrods, stock crank, stock cams + refreshed RB20DET and cheap Ebay bolt ons, etc -
The advantage of the SR20DET is more low down torque (longer stroke), lighter weight in front of car due to engine is lighter. The advantage of RB20DET is no rocker arm problems like SR20DET has and like I mentioned above more reliable with higher hp levels when using stock parts. RB20DET suffers the crank drive problem on front of crank (part that engages oilpump is not long enough and can strip, fail when engine is reved), but can be fixed when engine is refreshed, unlike rocker arm problem which can't be totally fixed (even aftermarket rocker arm stoppers can fail) on SR20DET. Also RB20DET has a 60mm throttlebody and SR20DET a 54mm throttlebody. SR20DE has a 60mm throttlebody and is a popular upgrade for SR20DET engines.
Should watch this race in UK, where the Cosworth with more hp, 4cyl engine competes against a Skyline with only a 400hp RB20DET. The Skyline with RB20DET is still competitive dispite it's hp disadvantage and passes the Cosworth -
It's multi part, so have to click on other videoclips to see the whole race.
Also RB20DET Skyline vs fast Cosworths in Australia, where Skyline wins the race -
About chassis, R32 Skyline chassis is stronger and supposedly has a better front upper arm setup. But I have seen some who build racecars revert back to R31 style at the front (same as 180sx). I gather because it's a more simple design, less to go wrong, less parts to upgrade.
Race version of RB20DET is well known for it's Hakosuka GTR type sound. As far as I know the 2 litre 6cyl engine was first used in Hakosuka GTR (58 race victories for Hakosuka GTR). So the 2 litre 6cyl Skyline engine has a fairly long history.
DR30 Skyline had the early version of SR20DET (FJ20DET) with solid lifter. GTi-R SR20DET has solid lifters, whereas S13, S14, S15 SR20DET have hydraulic lifters in the head.RESPONSE MONSTER
Only things that I can think of that SR has the advantage are: Cheap and easy to get parts, easier to work on, and also lighter.10 Infiniti FX35
09 Infiniti G37X coupe
02 Subaru WRX....sold
01 VW jetta 1.8T....sold
90-00-08 BNR32
92 NX2000...sold
95 S14 LE...Sold
Originally posted by ObsessedGtrKid View PostK so as you know im a newb to all this stuff so im just wondering which engine is better for reliability, gas mileage, and other things. i want to know in your opinion which is better for things like that?Black 1991 GTR. Serious garage stand mantle/parts car.
Originally posted by NismoS-tune View PostIs this for a swap or to choose a car based on reliability (which is not the way to choose a car, otherwise, you'd buy something new with warranty).
I allready almost jumped to a conclusion and was gonna buy a GTS-t but i keep seeing people complaining about there RB's being ticking time bombs and stuff but when i go on 240sx forums i rarely see bad things about the SR engine.
So now im going to gather info till the spring and make my decision then.
Originally posted by ObsessedGtrKid View PostSo now im going to gather info till the spring and make my decision then.
check the memebrs site maybe get a car with a bit of starter work done to it save yourself some hassle, ask yourself what you want the car to do?, bottom line Educate yoruself!!!!1992 BNR32 Skyline GT-R
Originally posted by bignateIf you are too lazy to search the site for info you are certainly too lazy maintain a 15+yr old JDM car.
Originally posted by archaeic_bloke View Postjust think about the platforms each was offered on.. RB 4 wheel steering, 4WD... SR = RWD only.How many kids with A.D.D. does it take to screw in a light bulb?
Wanna go ride bikes...
R.I.P \'87 4cyl Rustang
\'03 Dodge SX2.0
\'90 GTR32
