Ok, I'm making a r32gtr RWD
So I'm removing The front axles, diff internals, and prop shaft.
I'm going to simply pull the fuse for the atessa system, and maybe unplug the pump to prevent it from getting power.
Now the propshaft side that enters the transfercase is spline inlet. Is that open to fluid ? (shouldn't be right?)
I'm planing on plugging the hole so i can revert back if needed. Will this transfercase loose fluid? could i possibly damage anything by doing this?
I'll be installing modified Z32 Front knuckles, spaced tie rods, and chopping all the stoppers off the lower control arms. to maximize steering angle.
