Originally posted by Skym
View Post
Tuning options
They are known as Bullet Mufflers in the Northern hemisphere and they aren't that expensive (length is usually the problem) -
I think "Red Bullet Mufflers" is the commonly known name, as some come in red colour only. They are high flowing mufflers.
Just weld some flanges on each end with gaskets, done.
Also you can buy high flow cats that look like Bullet Mufflers.Last edited by Skym; 07-26-2014, 12:42 AM.RESPONSE MONSTER
Apexi or Nismo. Apexi are the best flowing exhaust due to the design (straight with less bends). But some exhaust's can sit lower to make them straight, which can hit speed bumps. I think custom exhaust is best, which tucks up under the car.
Should have 3x mufflers to make the DB level acceptable and have good sound.
Nismo exhaust's sound nice.RESPONSE MONSTER
If don't want to change what you have, a front / dump pipe (dump pipe is also known as a outlet pipe) upgrade (Xforce brand or similar) can help if on a budget. But I would retune ECU to suit, as R33 is a high compression engine and is sensitive to mild breathing mods making the engine run lean (need to retune ECU to suit to prevent knock from occuring).
As seen here a full Xforce exhaust (similar design to a Apexi exhaust) from stock turbo gives the best hp gains (note the catback is fairly straight, no sharp 90 degree bends) -
goes from 133.2kw / 178.6hp when stock
to
161.5kw / 216.5hp with just a full exhaust
Here is the hp gains with FMIC, full exhaust from turbo -
There can be up to another 38hp gain (aggressive tune, half that for a mild / safe tune) with MAP based ECU, retune, so over 300hp at engine quite easily with breathing, tune mods.
From memory a full boost up (including FMIC, injectors, fuelpump, etc) with stock turbo, stock engine, aggressive tune is around 235kw at wheels at around 11psi with stock turbo (responsive setup). With a safe tune it's around 220kw at wheels (kw x 1.341 = hp) which is common (average).
But that's all dependant on the engine being healthy (do a compression check). Also the boost up includes switching to heat range 7 sparkplugs with a 0.8mm gap.Last edited by Skym; 08-01-2014, 03:30 AM.RESPONSE MONSTER
My engine is very healthy actually. Lol. And I currently have .8mm gap. (It's in my project thread)
Looking at some japspeed products currently, Xforce don't make r33 exhaust now. The japspeed products seem far price and fair quality, just the shipping from the uk may bump it up.
I'll try and have most of my parts for the winter months and then try and get someone to do a tune/dyno day when the snow melts. Just need to find a person who tunes and is willing to travel here.
Another question(I have contacted them with out a response yet) if I get a plug in play haltech ecu can I get a base map from them or do some online tuning with them? Anybody have haltech ecu?Come on lotto!!! Daddy needs a whole lotta stuff!
They are a good ECU. Just make sure it's the correct ECU for the engine. Make sure it has 6x ignition drivers, 6x injector drivers which should be one of the top Link ECU's. Link have some that are circuit boards which fit into stock ECU case (same with ViPEC, which is basically the same ECU).Last edited by Skym; 08-13-2014, 01:15 AM.RESPONSE MONSTER
