Originally posted by malibusst
View Post
Are you talking about damage from piston slap? That should only occur if your piston to cylinder wall clearance isn't correct. If your block is machined properly to the specs of your piston kit, it shouldn't be a problem. Machining off your anti-detonation rings to put an 8 degree taper on the top of the pistons doesn't sound like a wise idea to me. Does Wiseco condone this?
In terms of your scoring Curt, does Rob think it's due to the pistons, or debris from the broken valves?
