I left the CD Mike made me at work but i will post the dyno slip i have it in PDF format... i was running 94 octane gas and the water meth is 50/50 and it has 2 plenum injectors for the meth one at the front of the intake mani for 1-2-3 and one i the middle of the mani at slight angle pointed at 4-5-6 both medium sized. I am running 1.8 bar but it seems to be creeping up to 1.99 bar which kinda worries me lol so i have turned down the boost controller a little till we get that sorted but when it was cranked holy sh*t it felt like the front wheels or wheel left the ground on me in second gear at like 7500rpm and pulled my car to the right and my steering wheel was straight, probably the front left tire getting 50% torque lol gotta get some diffs... the build happened pretty quickly and every minor mishap that did happened and that will happened it doesnt matter when you get your car back & its finally done and put your foot into it, thats what makes it worth it.
On another note the stock boost hoses are hating there life right now and are trying to pry themselves off everything... so i've taken a bunch of clamps off and replaced them with t-bolt clamps and they hold nicely. great upgrade... and yes stock boost piping is fine at 500whp... proven (knock on wood) also stock blow-off valves in with the re-circ hooked up also is fine all the way to 2 bar but holy they sound so wild at that pressure, total flip from stock boost pressure. the meth is great lol... well at least my car loves the stuff and bottles are cheap at Lordco (Staff discount)! The 1 gal container will last 2 tanks of gas approx.
Next on the list is some suspension and maybe a rear and front diff cause i now really need them both the rear is tired...
Also my roomate installed a fused on off lighted switch to disable awd into rwd just before the dyno and truthfully i havent used it yet i dont feel comfortable with the power yet and dont feel like roasting my rear tires just yet (They are getting low though)
Enough ranting pdf dyno slip will be posted
its 510 hp and 443 ft-lbs of torque the hp peaks at 6550rpm or around there and the torque at 5100rpm...
