thank you and i will!
RB26 Rebuild
Sticking up for you? bah I wasn't hating, just questioning. My bad.
So the 2860R-9s are the Disco potatoes? Just out of curiousity, the -9 are simply -5s with Larger turbine housings? (.86) or is the -5 with .86 different than the -9 with .86? They seem to have the same everything else. I'm still on the fence about which turbos so I'm asking all the dumb questions.Black 1991 GTR. Serious garage stand mantle/parts car.
The -5's have a larger compressor wheel than the -9'sOriginally posted by NismoS-tune View PostSticking up for you? bah I wasn't hating, just questioning. My bad.
The "Disco Potato" turbo is the GT2860RS, which is the same compressor and turbine wheels as the GT2860R-5, only with different non-GTR style housings. You could run them on a GTR, but the gains over the -5's would be minimal, if there are even any gains. You'd require all new charge piping, as well as new dumps and downpipes.
The -10's are a GT2871R, which shares the same turbine wheel as the GT2860R-5's, but with a significantly larger compressor wheel.1990 Skyline GT-R - Jet Silver Metallic
It'll run someday
Originally posted by curtisgoodman View PostI thought the disco potatoes were -10's either way i wouldn't go bigger then -5's anyways unless your going for a stroker kit or a rb30 ive just read a lot about -10's being laggy otherwise... with the proper mods you can get a lot outta the -5's and they respond way better...
I'm still not convinced on the whole way too laggy thing with the 10's, I'm getting boost on at 3500-3800 which I dont think is bad. What's so hard about with a quick downshift if needed?? Had a rip in GTR Dad's car, he is running 2860's like yourself Curtis. Very very quick spool great track course car set up.........Nothing but Good Times........
That sounds like not to much lag im just going on what ive heard and read. I guess it all depends on what rpm you want boost at max, what boost you wanna run and what you want your car to behave like on the road/track. the setup i have running could be considered a bit laggy as well... i start spooling a 3k rpm but dont get 1.8 bar till late in the 4k rpm range... if i change the stock boost piping for hard pipes i might get that a bit earlier though (TBA).
The bigger the turbo, the bigger the lag. But of course how laggy a car is is somewhat subjective!
There is a lot you can do to reduce lag with bigger turbos though, such as leaning the A/F and adding timing pre-boost, and eliminating any intake or exhaust restrictions, such as using a bigger IC, bigger IC piping, high flow filters with a good suction kit, big turbo elbows and down pipes, and a good test pipe. Bigger displacement, over-size valves and port work will also help.
Another great lag reducer is NOS! You can have it run at low-RPM, and then cut out as the boost comes on.FINAL CLEARANCE! EVERYTHING MUST GO NOW!
The Best Brands. The Best Builds. The Best Service. The Best Prices.
- 1.888.ZED.TUNE
What kind of compression did you end up with? Low 8s? How bout your tune, what kinda of AFRs are you running throughout the powerband?Black 1991 GTR. Serious garage stand mantle/parts car.
or maybe its always in the squatting position cause its ready to take off lol...
