traded my cefiro (skyfiro) for a gtr rolling shell
1990 skyline gtr with full gtr interior its going to be rwd with an rb25 so i can drift a lil bit
Parts List: Updated regularly.
Motor:
Series 2 rb25
rb25 tranny with 6 puck sprung exedy clutch
Side mount intake plenum
rb26 valve covers
3" 12x24 intercooler
AFE 4" air filter
aluminum radiator
autolite spark plugs
r34 coilpack cover ornament plate
blox oil filter relocation w/
russell fittings and braided line
blox water temp pipe
solid steering bushing
power FC w/ commander and data logit
power FC boost control kit
holset hy35 turbo
xs power top mount manifold. rewelded for strength
q45 throttle body
greddy oil catch tank with an lines and fittings
jecs 660cc injectors (reman by pfi)
P60 Q45 MAF
custom 4"-3" downpipe
custom oil cooler setup with an lines and fittings
aluminum 2 3/4" hotside and 3" coldside i/c piping
80mm stainless exhaust with autobaun88 test pipe
duel Tomei 340lph fuel pumps.
Greddy Timing Belt
Clear timing belt cover.
Turbo smart 50mm wastegate and screamer.
Blitz oil fill cap.
Tomei Type S FPR
Tomei PonCam's.
Suspension and wheels:
Megan racing coilovers i think they are 10k 8k
SPL adjustable fuca's
Cusco adj. tension rods
drilled brake discs
Bings Traction arms
Bings Rear Toe arms
Bings Solid subframe bushings
Project Silvia RUCA's
Energy suspension Urethane complete rear subframe bushing kit
Energy sway bar bushings
custom hicas delete brackets
Drag neo chrome lug nuts
steering bushing
KTS roll center adjusters
Megan extended tie rod ends
Work VS 18x11 +13 rears wrapped in 265/35
Work VS 18x9.5 +14 fronts with 20mm spacer wrapped in 235/40
Exterior:
GTR front bumper with N1 vents
GTR spoiler
N1 hood lip
N1 headlights
LED tail lights
Fujimura Rocket Dancer lip
Do-Luck Rear bumper
Do-Luck Skirts
N1 trunk lip
Interior:
bings drift button
nardi 350mm deep corn suede wheel
teal bubble shift knob
suede shift boot
suede e brake boot
Alpine bluetooth deck
nrg quick release
nrg hub lock
recaro reclinable seats
race tech center console gauges (below)
-water temp
-oil temp
-oil pressure
a-pillar pod
aem wideband
aem boost gauge
Nismo floor mats
pics of parts and motor
ill have pics tomorrow of the GTR and the motor swap
Motor:
Series 2 rb25
rb26 valve covers
AFE 4" air filter
aluminum radiator
holset hy35 turbo
q45 throttle body
P60 Q45 MAF
Greddy Timing Belt
Blitz oil fill cap.
Tomei Type S FPR
Tomei PonCam's.
drilled brake discs
Bings Traction arms
Bings Rear Toe arms
steering bushing
Exterior:
GTR spoiler
N1 hood lip
N1 headlights
LED tail lights
Do-Luck Rear bumper
Do-Luck Skirts
N1 trunk lip
Interior:
bings drift button
suede shift boot
suede e brake boot
nrg quick release
nrg hub lock
-water temp
-oil temp
-oil pressure
a-pillar pod
aem wideband
aem boost gauge
Nismo floor mats
