the bolts you'll need are M12x1.5 instead of M12x1
but you already have those bolts on the R34 setup, just reuse them, they are not 14mm
you can keeo the HKS lines at the front because the there is a hardline going into the caliper, which you'll need from the r34 setup
but at the rear the soft line goes directly into the caliper, thus the HKS lines won't work,
you can go to an hydraulics shop and have them make braided lines of roughly the same length, AN-3 size with M6x1 banjo fittings and bolts at the end
basically, copies of the stock rear soft lines, but SS braided
in my case, since the hydraulics shop i went to didn't have the exact fitting i needed, i had to use mutltiple fittings and adapters, hence why my rear lines look like this
From what I can see in the pictures there are no hard lines on the front spindles or callipers, So I might have to make something up as you did for the rears. As I'm working in Sault Ste Marie, the power train is being shipped to Brian's Autobody. I haven't actually seen it in person yet, but the seller provided nice video's of the compression test, as well as the motor with the current newspaper on the motor. Good to deal with so far.
However, I haven't got the brokerage bill yet.....
