Hello, my name is Ken, I have been building a RHD Honda for the last 8 yrs, and with most long term projects, I needed a change. The Honda was a Racecar in a widebody, I'm kind of getting to old for the Honda now, its too loud in many ways... LOL. So I came across this 89 GTR for 3g's. I didn't think it was a bad deal as I could part it out and get that. Here is the good side...
So as the title stated, she is bent up abit, the previous owner drifted it into a curb, and collapsed the drivers side suspension.... and bent the rear of the car abit.... So to the bad side....
My good friends family own a collision Body shop specializing restoring antique cars that have been bent up. They also have a reputation for exceptional attention to detail. After Brian sized up the car, he said that it was repairable and that it wasn't that bad. Perfect, that was the news I wanted to hear!!!! It also helped that a mutual friend offered up his 89 Gtr in mint shape to us to measure up, it is nice to have that...
It was time to start finding the parts to fix her.... The previous owner had ordered some used Spindles for the front and rear, as well as driveshafts. But when it arrived there were no suspension arms..... So the car sat for 1 yr as he didn't now what to do with it..... So all the arms needed replacing as they were all bent up. I did abit of research and ended up talking with Karim @ Toronto JDM, he hooked my up with all the needed arms, and was a pleasure to do business with as a bonus.
New to me Arms:
I also found a set of front Tension Rods on Kijiji for a 130 shipped, in hind sight I would have got it all from Toronto JDM but I had them ordered already.. So on my last rotation home I was going to put the suspension back in... But the Rear sway bar and front inner and outer tie rod ends are bent.... So in comes Karim @ Toronto JDM, a new to me swaybar and full rack & Pinion was shipped. I figured the rack & pinion might be good to have around as I don't plan on getting rid of the car anytime soon.
So that's about it for the bent parts, I guess by the time I get home the car will be on the frame straightener.... My overall plan for the car is to have the car straightened out, and to have a full rollcage with removable door bars, and main hoop cross bar. I want to retain access to the rear seats as I travel alot and this car is going to be driven.. I want the rollcage installed just to keep the car straight for the long term, Brian doesn't think I need it, but I will drive the car alot and I feel once you bend metal, it loses part of it's rigidity.
So here are some more pics... The Drivers side Interior:
The Passenger Interior: Needs a cleaning on the inside.... LOL
The car is in good shape consisdering, It has a few parts already, there is Apexi Filters, Spitfire Coils, and a strut tower bars front and rear. Here's the engine bay
It also has a Downpipe and a HKS Priest Cat Back. Here's the cat back
The Downpipes are alittle of a mystery to me, there is a multi-piece Tig Welded Bent in the downpipe that I haven't seen in any of the aftermarket offerings.. Here is a bad pic, there wasn't much space to get a pick... The second one isn't much help either..
I was thinking it might be a older Mine's piece but I'm not sure, maybe someone knows on here????
The car also has Ohlins Struts all the way around, and the only company that offers that combination is Mine's Motorsports. So I'm going to leave them in it for now. The Mine's description of the suspension package fits directly with my overall plan for the car. So onto the other parts I picked up for it, I found a Mine's ECU for a decent deal. I run a Stand alone in the Honda and I just want to get away from the laptop in the car. I want a more refined car, so I liked the Mine's Tuning mind set, it has to get to work all week, then track on the weekend. But if it doesn't work, a NisTune will be installed. So here is a pic of the Mine's ECU
The Description on the ECU was this...
Eliminate 180km top speed limiter
Shift rev limiter timing
Eliminate boost limiter
Modification of fuel correction map and Ignition map
Change quorum (k)
Change lattice of the map (RPM, injection time)
Modify every correction points
I'm not really sure of what Change Quorum means or what the Boost the ECU is tuned up to, but I will be running 14 psi. I would imagine that it is tuned to this level.
I also picked up acouple of Blitz DD BOV's for it... They need to be cleaned up abit,
So thats my start to the build, with any luck at all the car will be on the frame straightener when I get home, and I'll bolt up the suspension and we can get at making her perfect again, I'll be updating this thread as I'm new to the community and I figure this is a good way to make a few friends, and even get some good help and opinions.
Ken
New to me Arms:
Change quorum (k)
Ken
The previous owner didn't know where to find the parts.... or just ran out of money is probably the more likely answer. In the end he just went out and bought another skyline. He isn't mechanically minded, and I believe owning a skyline for him was a stature thing..... I wouldn't count on a car to get you laid but whatever... LOL
