Did you figure out what the problem was exactly?
Ricky Ricer's Rice Rice BABY!
Nismo rates them waaaayyyyy higher.
A lot of the high HP Aussies use them.The NISMO RB26DETT Engine Parts - Air Flow Meter is a direct, easy and a popular upgrade on RB26DETT engines as they are the same dimensions as the stock units. This is a popular and necessary upgrade for engines making serious HP! You will need 2 in order to replace your MAF system. These NISMO units can flow a max of 2400kg/h of air and support 775ps max power whereas the stock ones can only flow 1400kg/h of air and support 450ps max power.
I hear ya! Had to do the same when I did the 3M Dinoc wrap on my dash.Originally posted by Ricky Ricer View PostIt's been awhile since I've updated this. Not much is new. I repainted my interior trim flat black. I never want to do that again. The stock rubber crap is horrible to remove.
So while I'm bored here at work, figured I share some stories. First off, my car made it into DSport Mag from a local drag event in June. Was pretty awesome to open it up and see a huge picture of my car launching. If you go to dsportmag.com you can see the picture. I think the link for the event has my car on the bottom right.
Next, I took it to a track day at High Plains Raceway, and now it's leaking oil
There is oil everywhere under the rear turbo. We can't tell if it's coming from the turbo itself, or the valve cover (valve cover has been seeping since I installed the turbos). I've ordered a bunch of parts to replace the cams, cam gears, v/c gaskets, timing belt, N1 water pump, and Nismo thermostat.
