N1's I told you ! and people still say its impossible to hit 500whp with them ! awesome numbers I hope you love them as much as I do
Lucky gtr part 2 !!!!!! Back wit more !!!
almasi tuning in DELSOn CANDIAC !!!
BY ROBIN OMG HIS THE BEST !!!!!!
POWER FC IS GREAT !@!! I HAVE A BIT OF FINE TUNING TO do still cuz its map sensor but overeall wen i accelerate everything is super fine
the power band is INSANE !!! i just cant belive it !! 502 whp at only 18.5 psi !!!!
im actually way cool wit 11 psi 405 whp lmao its way ennuf fast for now hahahah imma keep the 18.5 psi setting for races :P wen something fast wants to try me :POriginally posted by gtrjon View Postnice man congrats you got your 500whp now go enjoy it
 how do you like the pfc? and what are you running for a ebc? the boost controller kit? or avcr?
i use the PFC boost control kit wich is really decent and my boost peacks a bit then it stay stable witiin 1 psi diff and then at end of power band losing like 1.5 psi
but overall again
11 psi 405 whp is damn fast compare to my 408 whp of before the power band is WAY way different !! i just cant belive it
It's not impossible with more displacement. An rb30 and n1 could do 500whp. Most likely though the dyno reads high for reality. When -5s normally need 1.2- 1.4 bar for 500whp, I'm guessing they'd do 600whp on the same dyno he used.Originally posted by evilgtr View PostN1's I told you ! and people still say its impossible to hit 500whp with them ! awesome numbers I hope you love them as much as I doNo build thread.
1991 nissan
El terror
Bah your right. I thought 500ps rating meant 500crank not wheel lol. So if n1s can do 500whp, my -5s can do 640whp fairly easily then (640ps) sweet!Originally posted by gtrjon View Postlol dude there is no way that the dyno over reads 100whp. yes dynopacs read higher but no where near 20%. and it all depends on how its calibrated.No build thread.
1991 nissan
El terror
Dynapak dyno definitely does read higher... and TW (on here) and I were talking about this the other day... we came to the conclusion that since my car was tuned on a mustang rolling road dyno, and we did 400 whp on the rubber at 18 PSI with 2860R-5's, I should go for a run on the dynapak dyno and see what it actually reads, do a real study on exactly whats the difference in reading
Dyno show down - Mustang Vs. Dynapak....lolThe SkyLife Community & News Website --> http://www.skylife4ever.com
Almasi's dyno reads higher then normal, from what I've seen (not hating just stating a point). Its how they calibrate the dyno, dynapak and mustang dynos both have calibration setups that your supposed to do every so often. Also you can put neg or pos corrections to inflate or deflate the numbers.
Either way 500whp at 18.5psi is pretty damn good, no matter what the dyno is.
That was on pump gas? 91/94?
100whp less at same psi but with bigger turbos... Does that even make sense to you? You'll hit like 600whp on their dyno lol then again the kid might have much more mods done.Originally posted by archaeic_bloke View PostDynapak dyno definitely does read higher... and TW (on here) and I were talking about this the other day... we came to the conclusion that since my car was tuned on a mustang rolling road dyno, and we did 400 whp on the rubber at 18 PSI with 2860R-5's, I should go for a run on the dynapak dyno and see what it actually reads, do a real study on exactly whats the difference in reading
Dyno show down - Mustang Vs. Dynapak....lolNo build thread.
1991 nissan
El terror
still have the shuffle the RB flows so much + i have cams + alot of goddies + 2.7 literOriginally posted by GTRADDICT View PostWhat happened to your shuffle you had before?
at 120 in 5 gear i run 2-3 psi witout even presing on gaz !!
its reallly really respoonsive more then anything i drove turbo before
mitch jai tuner avec du 94 !
Depending on which N1's a person is run ing and the supporting mods the engine it's difficult to say they are "maxed out" maxed out when talking about a turbo can mean a variety of different things, the N1's because of their smaller size generate more heat at higher boost 18psi + then some of the larger twins they are compared to, knowing this in advance I ordered a huge ARC intercooler as well as had intentions of running the aquamist meth kit to keep combustion temps and Exhaust gas temps down to a safe level. The proof is out there that the larger of the 6 different types of N1's - the Genuine R34 version - has produced over 650whp on race gas at 26psi. That's the highest documentation Iv personally seen. This summer I will be taking my N1's to 20-22 psi with meth and 94 octane and I won't be surprised to see 580+ whp. I will update as soon as it's done. Obviously every single engine is set up different but have a look at Mark Berrys high octane R32 GTR that car was easily putting down 550whp on BP ultimate pump gas and he was running the R34 version"LAG is the time the guy beside you thought he won"
Again with the dyno high vs low readings, please do your own research on this the facts are clear. I don't mean forum research I mean the real world tests that 0-60,Modified,Hot-rod,Motor trend have done. The dyna-PAC is the most accurate real world dyno on the market,explains why Formula 1 teams with $250+ million dollar budgets transport them around. The variance in reading comes down to how the dyno operator sets up the parameters and Cam showed me how easyily manipulated they parameters could be. The mustang dyno is Extremly accurate don't get me wrong,again it's the parameters in which it's programmed to read. Cams dyno is set up exactly how the dyna PAC rep instructed him to set it up, and guess what ? To test the theory first hand he ran the same car on both dyno's because he has a mustang dyno in the same bay. The results were a difference of 9whp which was less then %3. Iv had my car dynoed in Burnaby at Racing greed on the "heartbreaker" which reads notoriously low and everyone knows it. Jurie human tuned it there and it was rank he is awesome, They purposely run that dyno reading low - the reason is unknown to me,maybe it's so we can say my car has more hp then that dyno says. Il tell you personally the amount of money Iv spend I want to know every single hp my car has and it shouldn't change regardless of the dyno. What happens if you spend $4500 on some mods and take it to a different dyno and it reads low you wouldnt know the real affect those mods had on your car."LAG is the time the guy beside you thought he won"
