I had the head assembly to drop off this week also , they cc'd the combustion chambers to see if it's ever been machined before ( which it hasnt ) , and so they can work out the compression ratio and decide how much to skim it and how thick the head gasket needs to be to give me 8.5 :1 compression ratio. I'm still a bit indecisive on the head. I want to ditch the sodium filled exhaust valves because they are prone to snapping off using non factory cams.
I thought poncam b's would be ok on the factory valves but the increased trailing angle on the exhaust lobes with apparently add stress to them as them slam shut at a greater rate due to the extra duration so im going solid valves . not sure if i need to change the inlet valves too - they are already solid. I could always order a supertech head kit (phosphor guides , Nitrided inconel exhaust valves , titanium retainers , springs, stainless inlet valves and be done with it and sell the hks step 2 spring kit i have. More research needed ...
I posted elsewhere about oil pump choice , I think i'll probably procure a Tomei pump - it seems like the logical choice - these is so much debate on this subject it's almost impossible to make a solid decision based on any type of reasoning from points of view so i'm going to pay the extra for piece of mind..
I know i said i'm installing this all next winter but i'm excited as hell to get it running
a few hundred dollars is definitely worth the piece of mind.
