And once in place it looked like this .
It fits perfectly , there was mention of trimming a mounting bracket on the car but whoever installed the trust/greddy system originally has already done it so i didnt have to chop anything . there is plenty of clearance , nothing rubs , it looks made for this car.
another pic of the tip .
Once it was all hooked up i put the cat sensor back and reattached the heat shields
Here is a better picture showing the clamp and spring assembly . By the way putting on the springs was the hardest job of all (lying on my back trying to stretch them with a pair of pliers ) .
This is a view looking from the back though to the front of the car under the diffuser. The pipe caught the litter tray so i had to dremmel a large piece of it out so things cleared ok . Hard to see here but it looks good .
With everything mounted , checked and double checked , it was 11:30 pm . I decided to go for a quick drive to check it , and see what it sounds like. Its ALOT noisier than the trust system at idle , very imposing , impossible to ignore. let the engine warm up for 3-4 klm and then let it loose a bit . I noticed that the turbos seemed to spool faster ( although it was cold and damp out so hard to be accurate on this statement ). The wideband is running leaner by .2 across the board , still well within the limits of the ECU programming. Stomping the gas and letting it revout to 7500 rpm makes it sound like the end of the world has come. I sounds awesome , very loud - almost like a formula 1 car lol. When cruising it has a loud reverberating drone at around 2500-3000 rpm . However once you get into the 3300+ rpm range the noise decreases ALOT .. I'll probably use the silencer insert for long trips as i dont want to drive everwhere in 3rd gear to make it quiet lol.
I'm not sure how much attention the cops are going to give it , I usually get left well alone but that might change now. You absolutely cannot ignore this coming down the road anymore - a wonderful sound - but disrupting for sure
.... video to follow.
wil be doing something about that soon ) .
