INTRO
hi guys, please allow me to re-introduce my self again to the skyline community, my name is Felix Yuen, first started importing skylines since this whole craze began in 2004-05
this particular car was found by Adam @ Feast in 2006, long story short....just like all skylines...first motor blew up and needed a rebuild and that's how this money pit started.....
refer to my LAST BUILD THREAD as reference, at that time the car was at Keeps Performance Lab, being the FRIST rb30 in Canada and $60000 later, car blew up on RG's dyno...lets just say bad luck and i trusted the wrong people.
http://forums.gtrcanada.com/gt-r-pro...ect-horny.html
Car is now in good hands @ Evolution Auto Performance in Maple Ridge, they are a custom fabrication shop !
My last project was build by them and had very good success !
Project 9Up, 2007 Honda fit with Mugen K20 short block, Toda Head and custom turbo kit, 367whp @ 8psi.
http://www.fitfreak.net/forums/fit-p...ld-thread.html
again to cut this short, i had this RUST-LESS, PERFECT CONDITION R32 sitting in my garage since 2008 and haven't touched it since i towed it back home, it is now time to get it out and work on it again !
this will be another RB30 build using much of the old parts, some new parts and alot of custom fabrication !
aiming for high toque, and high power.....for going to shows, track, street etc.....
the GOAL is to have a COOL car to drive around !
RB30 - Project Horny Restart BY Evolution Auto Performance
Engine - BLOCK
-RB30DET
-CP Flat top pistons
-SPOOL forged rods
-ARP 2000 rod bolts
-balanced / polished crank
-Tomei Oil Pump
-N1 water pump
-Custom 4wd sump adapter plate
-ATI 1000hp crank dampener
-ACL bearings
-ARP main Bolts
-Tomei sump baffle
-Greddy over size pully kit
-Gates RB30 timing belt
-Cometic metal head gasket
BLOCK – MACHINE WORK
-Honed
-Rotating Assembly Balanced
-Enlarged Oil galleries
-Enlarged Coolant Passage
-Enlarged Head bolts RB26
-De-burred Inner Casting
-Machined Crank
-Micro Polished Crank
-Custom Crank Collar
-Drilled and Tapped New Hole for Timing Belt Tensioner
HEAD WORK
-Supertech 1mm over size Stainless Intake Valves
-Supertech 1mm over size Inconel Exhaust Valves
-Supertech Ti retainers
-Supertech Double Valve Springs
-Supertech Spring Seat
-Supertech Valve Guides
-Supertech Valve Seats
-Custom Head shims
-Grex 272 cams
-Tomei Cam Gears
-Drilled for oil return
TURBO KIT
-Greddy T78 33D single turbo
-Evolution Auto Performance Custom Exhaust manifold
-Keep Labs custom external oil pick up
-Keep Labs custom external oil return (turbo/head)
-Greddy racing BOV
-Greddy 50mm waste gate
-HKS turbo bell mouth
ENGINE OTHER
-Electric fans FAL Twin 12"
-F-win Radiator
-ARC oil cooler (grill mounted)
-Removed ABS, Custom brake lines (hidden)
-Trust 100mm intercooler
-ARC Ti cooling plate
-Trust coolant breather tank
-Custom 100mm stainless Keeps Lab exhaust
-Greddy intake manifold
-Nismo engine mounts
-Custom Catch Can
-Custom rad overflow tank
-Racing Battery relocated to trunk
-custom anodized earls fittings GOLD
-Evolution Auto Performance Custom intercooler pipes
-Stainless Rad hose
-Split fire coil pack
-Billion Power Steering fluids cooler
FUEL SYSTEM
-SARD 1000CC injectors
-Sard surge tank + Stainless fittings
-Areomotive FPR
-HKS 280L fuel pump X2
-Nismo 275L fuel pump x1
-Powerflow fuel filter (x2)
-Earles stainless lines
DriveTrain
-6spd trust dog box H pattern
-Push Pulled conversion
-OS Giken triple plate clutch
-Essential strengthen clutch piston kit
-Cusco front 1.5 way type MZ lsd
-Tomei T-trax rear 2 way lsd
-Nismo Steering rack bushing
-TEC Metal Steering rod spacer
Interior
-KTS 7pt Rollcage (custom padding)
-recarpeted rear floors
-Bride Maxxis Seats
-AC unit relocated to Glove box
-Defi Link Water temp. guage
-Defi Link Boost guage
-Defi Link oil Temp guage
-Defi Link oil Press guage
-Defi Link Ex temp
-Defi Link Fuel pressure guage
-Privat Speed meter
-Defi 80mm Tach 11000rpm (white face)
-Defi Link indicator II
-Custom Carbon Kevlar cluster
-Custom Carbon Kevlar center console
-Custom carbon center glove box
-Toggles switches / push start button
Exterior
-Greddy rear skirts
-Nismo f-bumper
-Custom Carbon bumper Lip
-Custom Carbom N1 side skirts
-Custom Carbon hood lip
-Custom Carbon N1 ducts
-Custom Made Angel Eye N1 headlights
-D-Max Hood
-Custom LED rear License plate lamps
-Nismo N1 Carbon Trunk Lip
-OEM Spoiler
-Fujimura CF Spoiler Lip
-Blitz I-Spark headlight blinker
Brakes / Suspension
-Cusco Tension rods
-Cusco rear camber arms
-KTS front camber arms
-VTTR Front 6pot 2pc rotor racing brakes
-VTTR rear 6pot Racing brakes
-HKS Hyper Max coilovers
-Metal sub frame spacer
-Cusco front & rear sway bar
-Custom over size Endlinks
-KTS lug nuts
-ALL Nismo hard bushings through out
-Seem welded suspension tower
::: SPECIAL THANKS TO :::
