Originally posted by tman7878
View Post
Tman7878's Rb26dett 240sx
Okay so its been a really long time since ive given an update. I dont have time to get you caught up on all the little details right now so heres the big issue I'm dealing with. I recently found out that my rear turbo is blown. SO.....WHICH TURBO SHOULD I GET? I wanna stay twin and keep response so I'm between the tomei turbos AND the garrett t2860r-7's. Final goal is just over 500hp so let me know what you think! also upgrading cams and doing some work on the head. Please gimme feedback on the turbos, thanks. Will post an update in the first week of september! until then I need to know what to order!1991 240sx - rb26dett
yeah I'm lookin for 500 at the crank so that might be an option. I want something that can comfortably be there though turbo wise like maybe give up a bit of the response just to know that my turbos are well within what they're rated too. Anything else I should look at beside the N1's, the -7's and the tomei's?1991 240sx - rb26dett
I got the -5 turbos with tomei type b cams 475whp @16psi and 582whp @22psiOriginally posted by tman7878 View Postyeah I'm lookin for 500 at the crank so that might be an option. I want something that can comfortably be there though turbo wise like maybe give up a bit of the response just to know that my turbos are well within what they're rated too. Anything else I should look at beside the N1's, the -7's and the tomei's?Being built...
I chose -5s kuz the response difference between them is very minor and u can get more hp out of -5s. I have fuel pump, 700cc injectors, tomei manifolds and
Outlets, z32 mafs, arp head studs, tomei head gasket and baffle, greddy fmic, twin turbo divided pipe, greddy profec b spec 2 boost controller, and a couple other supporting mods that dont rly give power. I still run stock fuel rail with stock fpr, and stock ecuBeing built...
Oh okay that sounds very similar to my setup except I'll be running a map sensor through my vipec, 600cc injectors, stock manifolds, but a tomei fuel rail so I'm hoping I can get close to what you're running. Still waiting for that quote from cam at lightspeed. Thanks for your feed back. He had suggested -7s so Ill have to ask why that is!Originally posted by allwheeldrifter View PostI chose -5s kuz the response difference between them is very minor and u can get more hp out of -5s. I have fuel pump, 700cc injectors, tomei manifolds and
Outlets, z32 mafs, arp head studs, tomei head gasket and baffle, greddy fmic, twin turbo divided pipe, greddy profec b spec 2 boost controller, and a couple other supporting mods that dont rly give power. I still run stock fuel rail with stock fpr, and stock ecu1991 240sx - rb26dett
I have major head work an now cannot rev enough because of the oil pump (peek is at 7200 rpm, dosent drop at 8300 but i wont go higher until i have the tomei oil pump) .... If you only want 500 hp dont touch the head it dosent need it at all500 whp Rb26 powerd 240 Sx on the way...
Okay thanks for the advice, I'm thinking I will go for turbos+ inlet exhaust manifolds and dump pipesOriginally posted by Vince View PostI have major head work an now cannot rev enough because of the oil pump (peek is at 7200 rpm, dosent drop at 8300 but i wont go higher until i have the tomei oil pump) .... If you only want 500 hp dont touch the head it dosent need it at all1991 240sx - rb26dett
