You guyz know me ,
616 whp @8200 rpm at 22.5 psi on 62-66 presicion turbo ,
SOLD everything almost and started from scratch again !!!
i Went the Rips direction , NEW zealand , ROBBIE WARD engine builder ,
here is the Final part listed for the GTR , no lie , after this im done just normal maintenence
ILL start wit the bloc :
RB30 bloc accid dipped , cleaned , prepped
NITTO Rb32 full stroker kit
ACL main / rod berings
ARP Head stud
ARP rod bolts
Arp main bolts
rb30 Timing belt
brand new idler n tensioner
Tomei Oil pump
r34 n1 WAter pump
Fluidamper crank pulley
Tomei Full gasket kit 1.2 mm head gasket
Greddy oversized oil pan extension
Head : Fully built by Rips again no corner cutted 10 .5000$ head job
FULL port n polish by Rips head guy (thats how they make their power (rob told me)
Tomei OVERSIze 1mm intake valve
Tomei Oversize 1 mm exaust valve
Tomei solid lifter
Tomei type b valve spring n retainer kit
Tomei bronze valve guide
Tomei cam cap stud bolt
Tomei cam gear intake n exaust
Tomei 280 DURATION 10.80 LIFT CAMSHAFT (INTAKE N EXAUST)
Custom intake manifold wit ITB remain
Spool oil drain kit
Turbo kit :
Presicion PT-71-75 GT42 STYLE (ball bering) divided , 1,12 AR
Hks Twin scrool manifold
Hks 60 mm waste gate 18.5 psi spring
4inch down pipe (rd turbo production)
Custom oil line feed / return
Drivetrain :
5 speed R33 Gearbox
OS giken Center plate
PPG billet main shaft
PPG 1-4 syncromesh gear set
ppg Billet forks selectors
Brand new SYncro R33 , berings, seals , gasket
C's shoft shifter
Nismo gt500 10mm 5 SPEED MT shifter knob
r34 Final drive Front DIFF , CUSCO 1 WAY type Rz
R34 FINAL Drive rear diff , Cusco 1.5 way type Rz
Driveshaft shop carbon driveshaft 1 piece
R33 nismo transmission mount
r34 stainless steel braided cluth line
Os giken TRiple plate R3C cluth kit
GREDDY FRONT DIFF COVER
gREDDY rear diff cover
Cooling:
Mishimoto radiator
SSR radiator cap
ARC COOLING plate
HKS Piping kit
ARC 4 inch INTERCooler
GREDDY 16 row oil cooler + relocator
5 inch KnN air filter
Cusco Modified 3 liter catch can
Aqua Mist water meth kit , 2x 1.0 jets Just before the intake Manifold
Wheels :
DRAG WHEEL R33 GTR wrapped in 275-40-17 mickey thompson
Street wheels WORK Rsz-R 17x9 +15 wrapped in Gforce kw2 275-40-17
Suspension /brakes
R34 GTR Brembo brake kit
DBA5000 2piece front rotor
DBA4000 REAR rotors
hawks hp plus brake pads
TEIN monoflex coil over
AMS TENSION ROD
AMS HICAS DELETE
AMS FRONT upper table
AMS REAR camber ajuster
Fuel system:
Greedy Twin entry fuel rail
injectors dynamic 2000CC
Braided line + Hicas line became FUEL line
Twin Intank Fuel pump 2X GTR pump (will see how it will perform if its good will stay like this , and maybe gonna go
wit 2 x 044 wit surge tank
Sard fuel pressure regulator
Electronics:
HALTECH platinum pro
racepack dash display wit every sensor possible almost
Exterior
N1 Headlight
Nismo front bumber
Nismo side skirt
Nismo rear valence
Misc parts
APEXI 3.5 inch Cat back
cusco rool cage 7 points
REcaro DC5 type R blue SPECIAL edition front seats /bride low position seats rails
Nismo rear strut bar
rear oem strut bar GTR
Nismo engine mount
Battery relocated in the trunk
BTW the transmission for this year will be A STOCK r33 gtr gear box , the wait on the PPG gear set if 4 month , so it will be getting build this winter while the car is in storage in a Brand new R33 box
Picture of the motor will be up soon wen RIPS send them to me , (2 weeks around)
Cheers !
ARP Head stud
ARP rod bolts
Arp main bolts
rb30 Timing belt
Tomei Oil pump
r34 n1 WAter pump
Tomei solid lifter
Spool oil drain kit
Turbo kit :
Drivetrain :
5 speed R33 Gearbox
C's shoft shifter
Cooling:
Mishimoto radiator
SSR radiator cap
ARC COOLING plate
HKS Piping kit
Wheels :
Suspension /brakes
DBA4000 REAR rotors
AMS TENSION ROD
AMS HICAS DELETE
Fuel system:
Electronics:
Exterior
N1 Headlight
Nismo front bumber
Nismo side skirt
Nismo rear valence
Misc parts
Nismo engine mount
Cheers !
