its either smaller turbo or time to dent out the shock tower to make it fit, you will have to put into consideration how much the engine torques too. Its sad if you have to bang out the shock tower since your engine bay is gorgeous.
Project Horny
This topic is closed.
if he does that then his power goals may be limited once the exhaust housing is changed.Originally posted by 240wide View Posthi there just get a small rear houseing made that can fit the same sieze fin
instead of denting your car1989 GTR R34 Nur/T67(SOLD
DD 97 auto hatch
waiting on the R34
What size turbo it that? You may have to go with a different or custom exhaust header (or smaller exhaust housing).
Regarding the battery, I ran one exactly like that only orange for about a year and a half. It was a Hawker Odyssey PC680 (pulse cranking amperage 680 -- only 290 cold crank). I have a little story for you. I blew off my intercooler piping once with that battery under the hood. After having flooded the intake with fuel, this battery didn't have enough juice to get my engine started again. Once I ran it dead, it never came back fully after recharging it. My suggestion is go for a battery that is a little larger and has at least 500 cold crank amps.BNR32 Owner
Okinawa, Japan
im pretty sure thats debateable, to find a housing that will fit that A/R and be smaller to clear the compressor wheel will leave the walls to thin. If the walls are too thin then when its heated up and cooled down the more likely it will crack. That housing is made that big to withstand the conditions it will go through while supporting that A/R exhaust flow.Originally posted by 240wide View Postno they wont because your still keeping the same size ar just a smaller housing1989 GTR R34 Nur/T67(SOLD
DD 97 auto hatch
waiting on the R34
Originally posted by Brewpubeaver View Posti think Tial is now making Exhuast housing that are lighter, and there for smaller, but still remaim the same AR size. might be something to look in to...
Is there anything that fits right on this?
so far every peice has to somehow make it fit
btw: anyone have a S14 KA power steering pump ?All parts sold are no refund/exchange
Honda tuning is a LifeStyle
Nissan tuning is to go stupid FAST !
Goals for 2013
Get the dAmn thing rUnning
so more progress today
made the apexi EVC into the test pipe
remember my turbo clearence issue ?
well instead of bangging out the shock tower, we modifided the exhaust manifold so it's more to the left
as you can see there are more clearence to the shock tower and less to the engine cover.
i also told u before that the water tube on the rb30 block is higher so the exhaust manifold needed to be ground inorder for it to fit
then we decided instead of having the waste gate vent back into the exhaust, like how it was before, we are going to externaly dump it, so we cut + patch the down pipe, later i am going to warp it with black heat warp
some random pictures
my clutch master (from EK9)
twin fuel filters
the guys working hard
some artistic stuff
aeromotive fpr
others
some pic of my fit
Goals for 2013
