g luck man please post updated pictures when u can..
Project Horny
This topic is closed.
Originally posted by felix yuen View Postdo u have his email ?
i don't have my space !!!
i gave it to you already, but if you missed it..
ej25jdm@gmail.com
because you cannot buy unless you know what size u need
and i ordered a set of tomei 1.7mm shimes to mesure toke 3 weeks for them to make ... sucksAll parts sold are no refund/exchange
Honda tuning is a LifeStyle
Goals for 2013
Get the dAmn thing rUnning
Originally posted by felix yuen View Postbecause you cannot buy unless you know what size u need
ok finally more work is being done
made new brake lines and relocated the proportioning valve into the inside of the car, it will be like the N1 cars where they have it at the driver side air vents
tomei diff installed (it was a bitch)
oil pan is being finished by machine shop....costing over $1000..****...gay ******* RB30....All parts sold are no refund/exchange
Goals for 2013
picture updated!!
finally more picture updates !
well it is finally look more like an engine, oil pan came back from machine shop,
and after all this stuff is done, i now realized even tho u pay alot of money for someparts. it still won't fit properly and everything u buy, HAS TO BE CUSTOM FITTED to have a 100% perfect fit!
here is why !
$1000 greddy intake manifold for example, the ports dont line up to the throttle as the holes for the bolts are drilled slighty off, heres wat we had to do
then who saids rb3o are a direct bolt onto rb26? if u say it is....u must be retarded as on our rb30/26 conversion, every rb26 part that is bolted to the rb30 block has to be customize, head bolts dont line up, tranny, sump, etc all has to be redone inorder to be fitted to the rb30 block perfectly
ex-mani/gasket has be grounded/trimmed at a few spots to clear
here are pictures:
here are a few random pictures:
differencese between the new greddy t88 ex-mani and old...look at the size!!
Goals for 2013
