Any info on Nitto pump ?
RB26 oil system
This is a sticky topic.
Originally posted by richard View Postwith a stock rb and no modifications what is the expected life span of the stock pump?obviously ill be upgrading asap and putting in a oil cooler at the same time but at what point do they typically fail?
That cant be answered.
Ive seen some early cars last and last and last. Couldnt really tell you why. But no body on this forum can tell you how long it will last. As long as the drive isnt stripping or have a crack in the pump gear, stay off your limiter and you "should" get plenty of life out of it. Its the bashing around on a loose clearance drive and pump on limiter that brakes oil pumps.
when you decide to update your oil drive, check out this link below for detailed info on the clearance issue.
ALLEN PETERSEN
Number (604) 961-2449
RB30`s for sale!
Any new updates with any of you guys?
I know a couple of ya have used accusumps. Where or how did you rout your goods?
I've recently looked at the tomei and nismo sump baffles. Tomei has the rubber door flaps and the nismo has a different configuration using metal doors. I also seen rips extended sump for the gtr and appears that with the design, only a metal cup surrounding the pick-up with some slots in the bottom. Almost looks like a crank pully socket welded in. I'm using a tomei unit for the price. Tomei was only $140 or something close to that. I heard the nismo is crazy expensive. Like closer to $500? What ones you guys using/like?
Thinking about the oil drain modification. (head to sump) Most guys have been routing it to the driver side of the sump just in front of the front diff. I was pondering that if it were on the other side the cranks rotation would help suck the oil down with a vacuum. (crank spins clock-wise). I might just split my drain into two and have it go to both sides on my next build. Hard to test this theory tho, so what you guys think of that idea?
Any other new things that can be added here?ALLEN PETERSEN
RB30`s for sale!
my car is street only (no tracks or autocross nearby) so I didn't go dry sump, otherwise I would have.
My oil capacity with cooler is 9L. With accusump is 12L. I have about 7bar oil pressure when driving. 2.5bar at idle. 300whp at 1bar fully built and -5 turbos. AFR is 9.8-10.3 at w0t. lots of flames from tail pipe haha.Black 1991 GTR. Serious garage stand mantle/parts car.
wow, 9.8 is quite the rich blend, almost scary rich. You might want to lean it out a tad in the mid-high 10s. Even 11s for a 300whp set up. Get beter millage and even get more power !
So, for an oil cooler, should I have a thermostat on the sandwich plate or just a plane 'ol sandwich adapter is safe ?
Just realized that the thread is old as sh*t... oh wellLast edited by Nismo20; 10-08-2013, 12:05 PM.Gotta love those twins
looks like it's gonna disconnect from your engine the moment you hit a speed bump.
wonder if it'll fitBlack 1991 GTR. Serious garage stand mantle/parts car.
Leaving this oil pump comparison guide here for easy ref.
Question:
For a street car, would the high flow oil pumps require increased sump vol. and head restrictor? Or is that an issue with extended high RPM track use? I haven't found any info on this, as I want to know if I need to install a head restrictor with, for ex, reimax gears.
Thanks
In my experience for street use the stock pump is more than adequate. Just don't frequently rev over 7500 and certainly don't hit the rev limiter.
I have almost 160k on my stock motor making 427whp and the car is used heavily on the track. No issues at all (knocking on wood).
If you do take your car lapping or do some Auto X just adhere to what I said above and add about 3/4 of oil to the sump and you'll be fine.
This is my honest opinion based on my experience. Some may argue.
If you are in the process of adding a high flow pump I would add the restrictor but I don't believe (for street use) the additional sump volume would be required. There is quite a bit of clearance between the crank and oil level making it possible to add oil over the oem suggested level. I use 5 liters when changing my oil.
I hope this helps.Last edited by bobbo; 09-15-2014, 05:20 AM.
