So couple days ago I noticed that when I was driving really slow it sounded like my front right brake was grinding or something. If I drive a bit faster (50km+) it doesnt grind but it squeels or squeeks (only noticeable outside the car). Im not a very good mechanic by any means, so im wondering what could be going on? not sure if this is a normal sound if they are just worn down, since it sounds like its clamped down a bit?
brakes
mines like a grind but not constant at low speeds.. its like grriinndddd(silence)grriinndddd as it turns slowly as if it wasnt an even surface. If i go faster the deep grinding noise isnt there but its replaced by a high pitched squeek/grind which i cant hear inside but i can hear outside (when driving beside curbs or cars etc. The noise is also there when I am braking, so really im not too sure..
If you have a brake lathe at home.....Originally posted by EtienneGignac View PostOr a warped rotor....shaving a little bit from each sides is an easy fix.
Don't mess with your brakes unless you know what you are doing. It's the last thing you need to have failing because of bad E-advice. Take it to a service station if you have to. Don't go killing a bunch of kids because you "thought" you could cure bad runout yourself.
Now, occasional squeaks, grinds can be as easy as rust build-up or rocks in the pads. What pads are you running? Does it take some heat until it makes the noise? Find the source of the noise..1998 Stagea AutechVersion 260RS
1991 GTi-R "Angry White Ghost" - FOR SALE
Of course I wouldn't do this my self. I'll get this looked into next time my car is in the garage. I'm not overly worried because it has no effect on brake performance. Just really annoying in rush hour traffic.Originally posted by Wingnut View PostIf you have a brake lathe at home.....
Now, occasional squeaks, grinds can be as easy as rust build-up or rocks in the pads. What pads are you running? Does it take some heat until it makes the noise? Find the source of the noise..sigpic
