GTR Wheel Fitment Thread
This is a sticky topic.
  • #91
    Did you use this?
    • #92
      yes i did. even tried comparing to oem wheel size
      • #93
        K, I have a fitment question: I'm looking at picking up some wheels, but I'm not sure about clearance on the inside.
        18x10.5, +38mm running at 265.
        Just curious if anyone can chime in I might have issues ( for a BNR32)
        Kevin S.
        Current: 1992 Skyline GT-R (on the way!)
        EX - 1995 BMW E36 M3
        EX - 1993 Silvia S14 w/S15 Front
        EX - 1990 Skyline GTS-T Type M
        • #94
          That offset is too high. Besides looking odd, you will most likely have fitment issues. Also depends on backspacing, which is a different meaurement than offset. Im running 17x10, +20 and I can just stick the tip of my baby finger between the inner lip and balljoint. Worst case grab some 15-20mm spacers if you really like the wheels.....
          Sent from my SGH-T769 using Tapatalk
          '89 GTST - SOLD
          '92 GTR
          '12 Mazda3 Sport Skyactiv
          • #95
            Hey guys, I have a quick question. I've been looking at rims for my R33 GTR and the wheels I'm looking at are 18x10.5 with a +22 offset. Should I have any fitment issues with that kind of wheel?
            1995 R33 Skyline GTR
            1991 R32 Skyline GTR - SOLD
            • #96
              You will be fine.
              10 Infiniti FX35
              09 Infiniti G37X coupe
              02 Subaru WRX....sold
              01 VW jetta 1.8T....sold
              90-00-08 BNR32
              92 NX2000...sold
              95 S14 LE...Sold
              • #97
                would i have to get my fenders rolled?
                • #98
                  That wont be an issue with an 18" wheel...17s have issues with a high offset (I had to grind the little bump off the end of the tierod to run a 17x10" +42 on the rear....no spacers). The rear should look fine but the front requires a bit less offset to not look goofy. On the flipside though, you can run a much wider tire with more offset, I run a 9" +18 on the front and a 245 is as wide as I can go. With a +30 on the front, I could go as wide as 275 on, say, a 9.5" wheel on the front with no rubbing issues and still look OK.
                  • #99
                    does 18x9,5+12 with 265/35r18 fit on r32 gtr without any bodywork?
                    • Originally posted by mistercrow View Post
                      yes they will fit. you wont need to do any fender rolling.
                      • -R32 Gtr
                        18x10 +18
                        Thoughts? Fitment?
