RB26 head build.
    Hmm... was he speaking good english? That's odd considering they claim to be extremely good with product support. What were you asking about?
      piston to valve clearence with 280 deg 10.8 lift
      Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
        Mark at ztune fixed me up with the awnser to my questions reguarding piston to valve clearence. anyone know what three bolts make it difficult to remove the head from the enginblock while it is still in the car, bellhousing?
          bolts 15, 16 and 17.
            are they actual head bolts, also are they under the valve cover or on exterior or head?
            If i have to pull the whole engine to change head i am just gonna rebuild it. it sucks i just had tranny out last august about 15-20 kilometers ago
            what do people think of Mahle pistons with Carrilo rods and a stock prepped crank for a budget build.
              Bolt #15
              Bolt#16
              Straight across from #16 you also have this one
              Bolt #17
              You certainly can pull the head with the engine in but it is a huge pain in the ass. Pulling the engine makes work much easier.
                I don't know how you'd consider a set of 1400 dollar top quality rods part of a budget build. My budget build is CP's on stock prepped rods with tomei rod bolts.
                1990 Skyline GT-R - Jet Silver Metallic
                It'll run someday
                  i was plannin on going os giken 3l or tomei 2.8l befor i had my son, so compared to those it would be budget.
                  stroker kit, or ...
                  crib/stroller/carseat etc...
                    What is it? These cams and other goodies are going in my head as well
                    Full-Race sponsored GTR. Anything else is half fast!
                    Full-Race.com
                      it clears if you dont shave head or deck block to much
                        Thanks man!
                        Full-Race.com
                          Always, always, always clay the pistons and manually check it to confirm though. Also, with the timing belt and con rods streching minute amounts at high RPM's, it's best to ensure you have some clearance room there.
                          It'll run someday
                            my budget build included wiseco pistons and eagle rods.
                            35,000+ km later still running strong and making fantastic compression.
                            • #29
                              Ya my budget is 6k for bare shortblock. ie rods,pistons,shells,studs,machine work.
                              I am already sitting on a tomei oil pump, tomei oil pan and n1 waterpump. i bought these 2 years ago
                              • #30
                                updated on main page
