So I recently had my engine rebuilt (less then 2000kms ago) and re-used the stock valve train because I was told they are very strong and will support up to 550whp.
Problem is I just found out that I may have a chipped or burnt valve on my exhaust side (found TDC and pumped air into cylinder and heard it hissing out exhaust - repeated the test 5 times with same result) I had my head vacuum tested, ported and polished and springs tested and a 5 angle valve grind done before it was all put back together and everything was good to go. I am having the issue with cylinder no.6 exhaust valves (cylinder no.6 is also the piston I melted when I killed my engine) so these valves have seen some extreme heat and stress.
My question for you experienced RB26 people out there is - what should I do when I have the head off - should I replace the damaged valves with OEM ? should I replace all the valves ? what about the seats ? retainers ? ( sorry if my lingo is out Im not familiar with head pieces or parts) should I have all my springs tested again ?
This is a big job and a expensive one and done want to do this again if I dont have to,I also dont want to sink $1000 - $2000 into the head.
Looking for advice on valve train set ups you guys are running and what works and what doesnt.
My target after this is done will be 550whp with the meth so Id like the top end to handle it,everything else has already been built to support.
thanks in advance for you advice and direction
cheers
cheers
