Engine is still in car and I have removed ALL THE BASTARD bolts from the plenum and disconnected the AAC all electrical and plumbing but I cant slide the plenum off the studs....I have it sitting on the very ends of the studs but cannot get it off....anybody have any ideas? I'm using like 6 flathead screwdrivers and prying on them evenly but no go........???????
trouble removing plenum
plenum is off WOOOOOOOOO
Bellis i used a 1/4 ratchet...a 3 inch long wrench....the back bottom 3 were the worste...for the 3rd one on the bottom from the back you need to do it from the bottom of the car...I got my arm up around all hoses and fuel lines while another guy pushed the wrench on with his finger and somehow I got it off...only took about an hour for the one nut...and I also used a long extension with a universal and then socket on end....the universal is extremely necessary or you will not get it off....make sure you take your aac off and all brackets holding fuel lines off the bottom...there are four brackets and 3 aac bolts connected to the plenum....Instead of using a 12mm socket on some of them i had to use a 1/2 which is slightly bigger because you cant get the 12mm on because of a little bit of angle that it is on....
This was the biggest friggin task ive had to do taking it off....next time it comes off i will pull the motor cuz that was extremely stupid while in car!gtr garage queen...anybody seen my wallet?
Originally posted by leeaspin View Postwhy not clean the throttle bodies?My Garage:
1990 Nissan Skyline GTR Nismo Edition - Action Hotdog Go!
2008 Audi RS4 - Hand Banana
1998 Subaru Legacy 2.5GT- Dirty Winter Car
1988 Toyota Supra Base - Trojan Judas Hairnet Battle Tree.
Originally posted by cortexx View PostHaha sounds good - wtf is a bittie ?Dang! You got shocks, pegs... Lucky! You ever take it off any sweet jumps?
