think I just killed my engine!
yes and I'm pretty sure it happened when I accelerated away from a lights, but my music was pretty loud.Originally posted by markc32 View Postdoes sound like a knock...does it make that sound at 2000 rpm n above when u rev it?1991 Nissan Skyline GTR (main)
2007 Toyota Tacoma TRD 4 door (baby wagon)
Worst case scenario would be $7000 cause your block is bad lol. You case, I'd guess at most $3-5k will get you a decent build to get 400whp safely and reliably. You could go into the big boy builds if you have lots of cash in the piggy bank. Anyways, best case, you need new bearings and a machine, maybe some piston rings, crank collar while you're there, gaskets.Originally posted by Smilez View Postno.
how do I tell if the engine is rebuildable?
what's my worst case scenario?Last edited by NismoS-tune; 12-29-2010, 03:00 AM.Black 1991 GTR. Serious garage stand mantle/parts car.
yes you must pull the motor and rebuild it. ive spun bearings on two honda motors and i am in the process of building my gtr right now. depending on damage you will need new rods (you might be able to get away with 5 of them but i always went with a new set) new bearings. and your crank might be scared. machine shop for a new hone. head gasket etc.... ballpark 2-4k?1991 Nissan Skyline R32 GT-R: 710whp 521 ft/lbs 27.5psi 11.8 @126mph low boost
Ohh, that's bad, no one likes chickenshit cranks. Better get rid of it or take it to a shrink.Originally posted by gtrjon View Postyour crank might be scared.
Originally posted by NismoS-tune View PostWorst case scenario would be $7000 cause your block is bad lol. You case, I'd guess at most $3-5k will get you a decent build to get 400whp safely and reliably. You could go into the big boy builds if you have lots of cash in the piggy bank. Anyways, best case, you need new bearings and a machine, maybe some piston rings, crank collar while you're there, gaskets.
That's a ball park based on possible damage.Last edited by NismoS-tune; 12-29-2010, 03:00 AM.Black 1991 GTR. Serious garage stand mantle/parts car.
1969 Cooper S. Restored
searail FTW...lol jks.
as for that sound... sounds like knock to me too.
you can get away with doing a ultra cheap rebuild... but the point is, while the engine is out, there are some parts that are just WORTH changing at the same time, because the parts are cheap and the labor is SO much easier while engine is out, such as gaskets, heater hoses etc.
I would say at the very least buy an R33/R34 crank... you can get a new one for $600 USD from nismo parts .com... or find a used one on the UK or Aussie boards (they go cheaper there then here but shipping might kill the deal)
don't machine you'r old crank its a waste... too many band-aids on old crank is a bad idea.
if u just wanna make it run again and do the very minimum possible... something along these lines might suffice:
- R33/34 used crank $400 (prices in canadian... best prices ive ever seen.. for cheapest options)
- new bearings *mandatory* $350... ACL race series... best bang for buck.
that would get you running for under $1000... assuming you havent damaged your block or rods....
if u can afford it, do the following while the engine is out also:
- new oil pump (anything is better than 20 yr old oem)
- new water pump
- Timing belt, idler, tensioner,
- full gasket kit to replace all engine gaskets and seals
- heater hose kit to replace all heater hoses under manifold
- replace vacuum hoses with new rubber ones
if u have even more money... its worth it to upgrade the turbos if ur still running stock turbos..
I'd start with pulling the engine out first.... remove the oil pan, and see what u can tell from the bottom before you pull off the head...maybe even see if u can't do a compression test first before removing the engine, that way if you know the ring seals are still hlding >150 PSI on all 6, you don't need to touch the head, or pistons... and as long as the bottom ends of the rods are ok, you could totally leave rods and pistons in the block and just do crank and bearings.The SkyLife Community & News Website --> http://www.skylife4ever.com
Sorry to hear it....
I've got a crank with a crank collar and set of Wisco pistons if you need them. Misc parts that may or may not help, but you're welcome to sift through what I've got. Price will be GRTC member friendly.
Dansigpic
The Beaumont Connection
