Simple match port of the exhaust gasket, PORT GURUS please check in, PHOTO!
Hi, im doing a simple gasket match to the head was wondering if i can remove this bulky area in the exhaust ports!??? I hope and there is no coolant passage behind it or anything else!!!
Yes there is a coolant passage , I wouldnt match the size of the gasket hole you're going to hit the passage or be really close.Remove the lump but dont go to crazy on it.
i would not remove this , if you think about it - the exhaust is exiting these ports and the most important thing when port matching is to make sure the gases arn't subject to a wall or "step" on its way out . If the exiting port in the head is smaller than the gasket and header/manifold there is no restriction so to speak, just a slight amount of turbulence.
Realise that the area just behind the valve where the gases first pass is also smaller than what you see here. This area isn't the most restrictive.
just remove hump... if you open up the exhaust too much your loosing too much speed and will result in less power
1970 Ford Mustang Fastback -> Fully Restored with Built 351W Motor
1993 Audi S4 -> 2.2L Turbo at 22psi with a few extra go goodies
1992 Nissan Skyline GTR -> RB31.5/26 Being Built Now
1994 Audi S4 -> Fully Restored and Tastefully Modded, 2.2L Turbo with Hybrid Turbo GT3071/K26 at 25psi
