Hey guys so im approaching the end of my build and i have left the fueling for the end lol. so i plan on running id 1000cc injectors with the powerhouse fuel rail but i am unsure of what i want to do with my fuel pump set up. i am looking to make 600-700hp and i dont know of any single pump that can supply that much fuel. so what is the easiest/cheast way to ger enough fuel for say 750whp?
Cheapest/easiest fuel pump set up for 800hp?
you will need a swirl por/surge tank for those numbers if you plan on running just pump gas (no NOS or meth) If you look on summit racing they have complete kits with surge tank, feed line, return line, and fuel pumps that wll meet your needs. When running a custom fuel set up like that your stock GTR pump is sufficient to supply gas to the surge tank then most people run a high volume pump to supply the fuel rail. Depending on where you live you will get mixed input on that pump : In the US guys like to run the Aeromotive A1000 - thats what I have, in OZ and the UK the twin Bosch 044 is very popular and of course in Japan the Japanese pumps like Tomei are favoured. Im sure they all do the same job it just comes down to availability and customer support for me. I chose the aeromotive pump and regulator because I can get parts anywhere and they are fairly cheap and the name has proven itself in the racing community.
Anyways have a look on summit there are some great deals and you will find everything you need to complete your entire fuel setup"LAG is the time the guy beside you thought he won"
option 1 . run twin 044's externally with the swirl pot fed by the gtr pump and twin -8 lines to the rails and a big return line to keep the pumps cool
Or
option 2 . Run twin in tank 044's with a phr top hat or you can modify the stock oneMy car keeps on stealing my money .
Get the powerhouse fuel hat, grab 2 walboros and call it a day. The fuel hat has duel feed option and will allow you to run an fittings into the hat from fuel lines. I have this for my set up and could show you exactly how to do this if you wantMiss driving sooooo bad! Need to get a car on the road ASAP!
cheap is relative 100000000 dollars could be cheap compared to something that is 40000000000 dollars. that doesnt mean im skipping any corners. and i never said i was going for 750 hp i said 600-700 and its more like 600 but for safety i need a set up good for atleast 750whp so i dont lean out and i always have enough fuel. thanks for your helpful imput thoOriginally posted by hozer View Post2 words you must remove from your vocabulary when going for 750WHP1991 Nissan Skyline R32 GT-R: 710whp 521 ft/lbs 27.5psi 11.8 @126mph low boost
cschepp could you pm me some more info plsOriginally posted by cschepp View PostGet the powerhouse fuel hat, grab 2 walboros and call it a day. The fuel hat has duel feed option and will allow you to run an fittings into the hat from fuel lines. I have this for my set up and could show you exactly how to do this if you want
Words of a wise man good sir.... Get a RIPS tank for your given HP range. That's what I have and it works awesome, also this way you have some back up if a pump fails on youOriginally posted by archaeic_blokehows the warp drive? i've seen far too many GTR's lately that just arent able to hit warp speed.
lol ill be running meth for sure. lots of boostOriginally posted by evilgtr View Postyou will need a swirl por/surge tank for those numbers if you plan on running just pump gas (no NOS or meth) If you look on summit racing they have complete kits with surge tank, feed line, return line, and fuel pumps that wll meet your needs. When running a custom fuel set up like that your stock GTR pump is sufficient to supply gas to the surge tank then most people run a high volume pump to supply the fuel rail. Depending on where you live you will get mixed input on that pump : In the US guys like to run the Aeromotive A1000 - thats what I have, in OZ and the UK the twin Bosch 044 is very popular and of course in Japan the Japanese pumps like Tomei are favoured. Im sure they all do the same job it just comes down to availability and customer support for me. I chose the aeromotive pump and regulator because I can get parts anywhere and they are fairly cheap and the name has proven itself in the racing community.
anyway i think im retarted but ive been on summit racing for half an hour and i cant find any swirl pot/surge tank kits!!!
a kenne bell boost a pump is another way to get more flow... 600whp plus on a walbro 255 with one has been seen lately in a bmw application
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.
a swirl pot isn't necessary if you want to save some cashLast edited by Black BNR32; 05-08-2011, 12:06 PM.oh hai!
