Cheapest/easiest fuel pump set up for 800hp?
  • hozer
    replied
    Originally posted by gtrjon View Post
    easiest/cheapest way
    2 words you must remove from your vocabulary when going for 750WHP
  • DJ
    replied
    option 1 . run twin 044's externally with the swirl pot fed by the gtr pump and twin -8 lines to the rails and a big return line to keep the pumps cool
    Or
    option 2 . Run twin in tank 044's with a phr top hat or you can modify the stock one
  • evilgtr
    replied
    you will need a swirl por/surge tank for those numbers if you plan on running just pump gas (no NOS or meth) If you look on summit racing they have complete kits with surge tank, feed line, return line, and fuel pumps that wll meet your needs. When running a custom fuel set up like that your stock GTR pump is sufficient to supply gas to the surge tank then most people run a high volume pump to supply the fuel rail. Depending on where you live you will get mixed input on that pump : In the US guys like to run the Aeromotive A1000 - thats what I have, in OZ and the UK the twin Bosch 044 is very popular and of course in Japan the Japanese pumps like Tomei are favoured. Im sure they all do the same job it just comes down to availability and customer support for me. I chose the aeromotive pump and regulator because I can get parts anywhere and they are fairly cheap and the name has proven itself in the racing community.
    Anyways have a look on summit there are some great deals and you will find everything you need to complete your entire fuel setup
  • gtrjon
    started a topic Cheapest/easiest fuel pump set up for 800hp?
    Hey guys so im approaching the end of my build and i have left the fueling for the end lol. so i plan on running id 1000cc injectors with the powerhouse fuel rail but i am unsure of what i want to do with my fuel pump set up. i am looking to make 600-700hp and i dont know of any single pump that can supply that much fuel. so what is the easiest/cheast way to ger enough fuel for say 750whp?
