Originally posted by cobrAA
View Post
What ECU do you guys have ? Haltech , AEM EMS , Power FC ??? (500hp+)
lol my 1000000awhp gtr could be slower than yours and i couldnt care less. what i do care about is your pointless newb posts. you would think that with how much time you spend on this forum you would of obtained some basic knowledge about you're car and the parts your buy, or in this case the parts that you dont. clearly that isnt the case since you dont think any features of an aftermarket ecu are functional.1991 Nissan Skyline R32 GT-R: 710whp 521 ft/lbs 27.5psi 11.8 @126mph low boost
From the short chat I had with my tuner, this is what I took from the conversation:Originally posted by Marus92 View PostIs the stock ECU using throttle for the maps? 'Cause that could explain a few things on my end...
The thing about tps controlled mapping is that there is no real compensation for changing load values ie: pulling up a hill where more throttle is needed at the at the same rpm that might be used for just cruising speed on flat ground. So ultimately to be safe it needs to be tuned on the rich side.
I could be mistaken but this all made sense coming from the tuner.
I'm not a tuner and don't think I will ever have the patients/courage to attempt tuning so take this info with a grain of salt.
Cheers
Sent from my Galaxy Nexus using Tapatalk 2
I think you should concentraite more on the main part of his statment - of how to run 650hp gtr on stock ecu??? and not the part about yourself!Originally posted by cobrAA View Postyeah all gadgets that sound good on paper but barely do anything IRL..
dude you have SERIOUS ISSUES, you always have to start your post by saying that i have 3700 post and I'm such a keyboard warrior. I mean seriously knock it off your just beeing a total douche. Just ignore me. I seriously couldn't care less if a guy 5000km away from me doesnt like me or not LOL! whats next? your going to tell me your 512whp gtr is faster than mine? I see it coming, real soon!TTBB is a true ACN member
Thx for all these answer , i'll do some more research on the Vipec and the Haltech . I need to compare the price too . No i wont take a cheap ECU to save money but im pretty sure that the AEM Haltech and Vipec will do the job if its tuned properly . I'll try to find wich one offer the best combo/price. I dont have my A/f gauge , boost gauge etc yet so im trying to find a great ECU/Gauge/Sensor deal that match with each other . If one of you know somebody or saw a trhread about selling a good ECU let me know !
Another question , im in the area of Montreal Quebec . Who know a good tuner that did some map for a 500hp+ GTR single turbo with Map sensor .
Robin Almasi is the man and he will tell NOT to go with AEM.Originally posted by RB26DEBIGT View PostThx for all these answer , i'll do some more research on the Vipec and the Haltech . I need to compare the price too . No i wont take a cheap ECU to save money but im pretty sure that the AEM Haltech and Vipec will do the job if its tuned properly . I'll try to find wich one offer the best combo/price. I dont have my A/f gauge , boost gauge etc yet so im trying to find a great ECU/Gauge/Sensor deal that match with each other . If one of you know somebody or saw a trhread about selling a good ECU let me know !
Another question , im in the area of Montreal Quebec . Who know a good tuner that did some map for a 500hp+ GTR single turbo with Map sensor .Last edited by cobrAA; 11-06-2012, 08:29 AM.Need detailing done to your car? I'm open to travel to detail your car :
ECU that you use depends on application (street, drag, racetrack, etc).
Stock ECU has knock control, 16 x 16 maps. Very basic ECU, but works with stock or close to engine configuration with stock revlimiters, etc. It's designed to make engine last (reliability).
Link, ViPEC ECU (20 x 20 maps) because they have barometric (altitude), IAT (intake temp) compensation and can run a ROSS crank trigger setup if necessary (to replace CAS and get accurate ignition timing on high hp engines). Barometric compensation can be an option (including sensor) on some ECU's. Knock control is an option via fitting knock block. Not ideal for high reving dragracing engines, but can be used on street or track cars.
If highend drag engine, etc, Motec ECU (40 x 20 maps) because it can do what Link, ViPEC ECU's can do and has more rpm rows (40rpm rows vs 20rpm rows on Link, ViPEC, PowerFC, etc, 16 rpm rows on stock ECU) and has Motec ignition, coilpack upgrade option, datalog shock travel, driveshaft rpm (to tune clutch), etc. More rpm rows = more control over shape of power, torque curves or can rev engine higher than stock rev limit's. These options, features is why it's used on the engines of the fastest imports on the planet and on racecars, etc.
From what I understand, TPS makes ECU switch to different load cells (which load cell to select that's richer or leaner on fuelmap and same cells on ignition map) and relies on fuelmap being tuned correctly to match mods (if lean out engine, transient fueling is leaned out at same time). Basically the same thing as what MAF does, but TPS reacts instantly to throttlebody suddenly opening (MAF is too slow to react).Originally posted by Marus92 View PostIs the stock ECU using throttle for the maps? 'Cause that could explain a few things on my end...Last edited by Skym; 11-06-2012, 09:12 AM.RESPONSE MONSTER
In the end, ecu topics are pretty much just fanboy bs. except anything you hear about power fc is probably true. that thing is ancient! Talk to your tuner and ask him what he wants to tune your setup with. There's no point in spending $1500+ just for your tuner to ignore all the extra options that available in the ecu you bought.
Seems that alot of tuners are arrogant about tuning something they don't know very well. Seems like they don't want to expand their knowledge base. You should use that as a tool for picking the right tuner.
I dunno. Good luck?
if u are good tuner,than u will make RB work even on Megasquirt.There are tons of 500-700hp 1/4 projects working with lo budget SA ECU and they are doing 9s with just few options like LC,NO2 controler etc...I have 2lt opel kadett 500whp on Megasquirt (200$ with inovate WB02) and can do 1000cc on 0.2 sec at idle for 15AFR and did WOT 280kmh passes on autobahn many many times...
as for here,think that VIPEC is way to go for SA...but if all that is DIY,there are many cheaper options there
I have nothing bad to say about haltech however AEM did nearly cost me my engine
When the meth controller decided to pump 4 liters of spray into my intercooler while the engine was not running.
Not impressed at all.
I had my reserves about AEM when more than one tuner expressed dislike and even called it
" Almost an Engine Management "Favorites
lucky_cefiroentelijintyou\'re not listeningstop saying "yall"... i'm picturing you with a mullet.
mullet+skyline=*shiver* i dont even want to think about itOriginally posted by specialeditionHe ended up popping a tired and he failed at life.
Use a vipec!!
heck, even got mine for sale!Black 1991 GTR. Serious garage stand mantle/parts car.
Really it boils down to "what are you using the car for". If all you are doing is a street car that can shock and awe on occation then a D-Jetro with DataLogit is hard to beat. Sure the fancy pants ECUs have more features but, do you really need them. Especially at two to three times the price.
If you are a hardcore racer and need the incredibly precise control that the fancy pants ECUs can give you (because you race in a class that only allows 2 fuel stops and you have tuned the motor to within an inch of it's life to make it to the end on the fuel aloted) then spend the money.
A Djetro can SAFELY handle 1000whp all day long.
Jon.Last edited by Dragon Humper; 12-02-2012, 02:36 PM.Why don't you come over to MySpace and Twitter my Yahoo untill I Google all over your Facebook.
I am using an AEM V1 with throttle based MAP compensated setup. I agree that AEM EMS is very complicate to tune. But, once everything was figured out, it is a very capable and reliable EMS.
However, if your tuner is not comfortable with AEM EMS, then do not buy AEM EMS.Last edited by xcye; 12-18-2012, 02:05 PM.
I like the Power FC L Jetro. MAF is the way to go. D Jetro works well too, but I personally think MAF sampling is more accurate than MAP database calculations. Eric Hsu also thinks the Power FC L Jetro works great, prefers using it for street driven cars.
That being said, my silver car has an AEM v1 with MAP. It is what it is, it works, not that thrilled about it, but I'm not buying something else just for the sake of not using a working AEM EMS.Nick
