First a few questions about fuel components,
what is the largest injector that can be fitted into the stock rb26 fuel rail? is the stock fuel rail injector size 11mm?
Anyone using the AEM high volume fuel pressure regulator, or the Aeromotive a1000 fpr? which one would be a better choice, I had a ebay one, but it leaks like crazy so its not going to be used.
I have a Vipec ECU which will be getting tuned in the car in the spring, In order to control boost, what will be required? I have a Apexi boost control valve already wired from the location of the ecu to the engine bay, im wondering if this will work?
There is a AEM water/meth kit in the car also, should anything be wired from this to the Vipec?
Last thing, Injectors. What is the best bang for buck injector? does anyone run RC? or Deautswerks?
Trying to pick away at as much as i can before it gets finished up and dynotuned. Mafs are eliminated, and map sensor vacuum line is run to ecu. Wideband output wire is also run to vipec.
Thanks alot, the advice is appreciated.
