If you work very carefully and really take the time to measure and measure again, you should be able to section the length you need out of the stock arms. I would just butt-weld the pieces together again, then box the arms with a strip of same thickness steel to make them rigid and re-enforce the joints. The lowers, you should be able to just move the inner pivot points right next to the cross-beam, that should give you about 1.125". With about 2deg. of camber, you might be right in the ball park.
