Koyo rad + flex-a-lite electric fan
    Got any pic ?? Im interrest how you do that you put the whole probe sensor inside the upper hose and you only see the wire comming of the clamp??
      exactly
      - Adam
        it's basically a metal wire coming out of the upper rad hose with silicone gasket securing any leaks. my friends eventually corroded from the wire and sensor and stopped working, I think his concentration was too high on coolant. Another alternative is buying a Radiator hose temp sensor adapter. they range around $25.00 - $50.00
        The greddy one is a good one, or depo also.
        Link ECU / Nistune / Apex'i / Greddy / HKS / Cosworth / Megan Racing / Agency Power / Tomei / Perrin / Cobb / Aeromotive / Stance / HSD / Battle Version
        AUTODREAM.CA
        P: 403 248 1566
        F: 403 568 0567
        E: info@autodream.ca
        Invidia / Tanabe / Tial / Vibrant / Cusco / Nardi / Momo / Sparco / Proper+ / Yonaka / Varrstoen / Rays / Work / Enkei / Bride / NRG / Compustar / and more!
          Just tap into the factory temp sensor at the bottom of the rad for the AC. The switch temp is a bit high for my liking but, it can work. You could always replace the factory switch with an aftermarket one with a lower temp.....that's what I am going to do with mine.
            I have a greddy rad hose adapter for a temp probe, 30 bucks plus shipping id ya want it.
            2003 350z track
            1990 Skline GTR
            1995 240sx
              Ok tanks guys i already have one but my main question is wich fan controller its the best or what is your coolant setup??
                If i buy this kit
                Buy and sell electronics, cars, fashion apparel, collectibles, sporting goods, digital cameras, baby items, coupons, and everything else on eBay, the world's online marketplace
                And just buy a sensor from flexalite it will work??
                  That kit is a sensor.
                    Ok so i will try the kit
                      It should work, u stick the probe in the rad, or the hose, it heats up and tells fan to come on, are u switching from oem clutch fan?
                        Yes because i change to a koyo rad and it came with a flexalite fan anyway my clutch fan is crack so good thing
                          That's normal for the fan to crack like that, e fans are not as good, just b sure to keep your shroud and fan in case u want to switch back
                            E fans are better, just don't buy the cheap ass ones. My last 4 vehicles have had E fans. The GTR is the only one with a clutch fan and its going bye bye real quick. My 2011 Silverado has E fans, its rated to tow 11500 lbs.
                            • #29
                              I know, most new vehicles have e fans, they prob are better, my twin mishimotos don't keep it as cool as the clutch fan, and there's been a couple people who switched back for the same reasons, I'd like to change the blades on my fans, to something with a little more pitch, they are pretty flat, compared to the clutch fan. Or it may be because the clutch fan is always spinning, but the Efans only come on when up to temp, could always wire them to come on with ign
                              • #30
                                Yeah but if you wire it up with the ignition i hear that the fan wont last long
