So today i went out to break in my new twin disc clutch i installed to break it in... (all down hill from here) I drove around for around 100kms and all was well until i hit it a little in 2nd gear and thats when all hell broke loose. While i was getting into the throttle the car made a funky noise and stop building boost and only wanted to putt around. So i pulled over and checked under the hood to see what was going on. I found that my manual boost controller line had popped off as well as another line behind my fuel rail. So hooked both of them back up, but still had the same issue. It just wasn't building boost at all. As if it were being restricted somewhere. So i putted back home and removed spark plugs. They were very black as i expected. from there i installed new plugs and started it. My AFR started at about 16.2 at idle then slowly started to drop back down to 10.0 again. So i took it out for a quick test drive but still the same issue. Car is running very very rich. My AEM AFR gauge says 10.0 flat and never really changes at idle nor when i get onto the throttle. So i went back through and checked all of my couplings for leaks and didn't see anything out of the ordinary.
Anyone ever experience something like this or know what could possibly be wrong? I am open to all suggestions.
