Just putting it out there again to see if anybody has come up with a workable solution to replacing the shaft seals on the RB26DETT throttle bodies. I know there used to be a kit from xspower or something but they are no longer around. I've looked around for another replacement but haven't come up with anything that will properly fit. If anyone has come up with something please post it up. I imagine almost everyone with a GTR is going to experience the need for these at some point.
Throttle Body Shaft Seals
I don't know if I'd go to a single TB because of a seal issue (lots of pros to ITB's) but if you're always on the throttle I guess the single is better?
Bah, go single, will look better with a huge turbo and large plenum!No build thread.
1991 nissan
El terror
Yeah I definitely will be keeping the ITB's its just a matter of fixing the leaks. I have no interest in a big single or buying any new parts, just venting my frustration in how hard it has been trying to located some seals. Its unbelievable that Nissan doesn't have a part number for them.
Update to my last post, I got a call back and the guy found something he thinks matches that number. Ill get them on Monday and report back as to whether or not they are correct. The seals are around $4 each so the price is right...in the name of science.
i did some searching with that part number, pbr is the manufacturer. that part number references to a size 10x18x6. so a regular nitrile oil seal of those dimensions i believe would work. i couldnt cross the number to anything else but those dimensions should definitely aid you.
