Fuel wash down of the cylinder walls can cause increased wear due to the lack of oil film. That may be your issue. You best bet is to do a leak down test and compare #6 to the others and if you have a more increased leak to the crankcase you'll have to replace the rings.
Car won't start after head gasket and camshaft install
Yea, the way my setup is now it only takes around two hours to pull the head so not really a big deal. Just pulled it last night. My valves are fine, not bent, piston's are fine no contact at all between valve and piston, and cylinder walls aren't glazed. Looks to be I need to get my number 6 valves reseated, head pressure tested, and cleaned.
The question I had is whether I can reuse the Apexi metal headgasket I just installed. It only ran for about 5 minutes at idle and the gasket hasn't been crushed flat, still has the multi layer "spring" to it.Last edited by dylanc; 05-03-2015, 01:56 PM.
